Flathead oil pump gear removal?
Discussion in 'The Hokey Ass Message Board' started by Ralph Moore, Oct 23, 2010.
  1. Ralph Moore
    Ralph Moore
    OK, I give, how do you get the idler gear that goes from the cam to the oil pump off of an 8BA block?
    I've done 59A-B's many times and they just fall off when you pull the back cover, but this is the first 8BA I've torn down. There are threads in the center of the flange that holds the gear on, is this for a puller?
  2. Ralph Moore
    Ralph Moore
    Bump. Where are all the flathead guru's?
  3. Da' Bomb
    Da' Bomb
    I use a slide hammer with 3/8 - 16 stud. It's a light press into the block, so it comes out fairly easy. Or you can drive it out with a punch from the valley side of the block.
    Pat
  4. Ralph Moore
    Ralph Moore
    Thanks, I didn't want to go at it blind and damage something.
  5. RAY With
    RAY With
    I agree with pat--I use the slide hammer as to me its the fastest and no chance of damaging any thing.
  6. 4dFord/SC
    4dFord/SC
    On the Fordbarn:)
  7. Ralph Moore
    Ralph Moore
    I have been enlightened! I'm there.
  8. Slide hammer, or screw a bolt into the tapped center of the gear and prise it out with leverage.....lol !
    Rat
