Technical flathead idle but hesitate to rev up!
Discussion in 'Traditional Hot Rods' started by rodderbilly, Feb 16, 2014.
  1. rodderbilly
    rodderbilly
    from italy
    1. Rockabillies of the HAMB
    Hi all hambersnow i need your help for my problem...i have two 94 and the front is without choke....i open and clean the carbs . ...i registre the carbs with uni-syn and engine idles good...but when i pull on accelerator the engine stall and hesitate to rev up about 2-3 seconds then rev up good....i notate when i open the front carb that has the fuel pump spring a little rusty....this is the cause of my issue?the engine has some backfire, i have 4.5 power valves ,main jets are 51 ..can you help me?was thinking to change the main jet to 47 or 49.......
  2. Check you float levels sounds like it flooding.
  3. Do you have a good, stong accelerator pump stream? Does the exhaust look black or smell rich?
  4. nsh57
    nsh57
    Sounds like flooding. Check floats & fuel pressure first. 94's hate too much pressure. 51 jets should be ok to get going, depending on cubes of engine. Which of the 3 holes do you have the throttle pump hooked to? Should start on the lowest one.
  5. rodderbilly
    rodderbilly
    from italy
    when i open the carbs floats seems to be good ....thinking to open another time and check more accurate that floats,fuel pressure is near 2,5-3 psi.....the throttle pump in the 2 carbs are hooked in the middle....only i remember that i try the spring on front fuel pump with some rust...
  6. rodderbilly
    rodderbilly
    from italy
    yes a lot of smell rich....
  7. Kiwi 4d
    Kiwi 4d
    Wow cool to see there are flathead rockabilly HAMBERS in Italy. Sounds like a lean out on sudden pedal down. Have you checked the accelerator pump and that the power valves are all good. Is the pump rod connected?
    We hope to be in Italy around April . But will only be tourist stuff in Rome.
    Don't expect there are many rockabilly joints in Rome. Let alone flathead guys.
  8. rodderbilly
    rodderbilly
    from italy
    Hi Kiwi..i see the power valves and they are in nice conditions with no cracks...yes pump rod is connected in all 2 carbs....a thing that i can say is that when i acclerate by hand on the pump levers the squirter on the rear carb sprays less fuel ...i think i have a accelerator pump problem...
  9. When it does catch after that 2-3 second dead spot-
    Watch the exhaust for black smoke and rich smell.
    If yes
    you have black smoke and rich smell
    then the problem is too much fuel when the throttle opens.
    If no black smoke and smell
    Then the problem is not enough fuel when the throttle opens.
    The backfire is also a hint to the lean condition.
    Most of the time a good idle with a Bog on throttle is a lean condition caused by accelerator pump malfunction.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    Have you rebuilt your carbs yet?? Don't sound like it..
    Read this thread.
    http://www.jalopyjournal.com/forum/showthread.php?t=155818
  11. tommy
    tommy
    Did you play around with the timing any to see if it improves?
  12. Paul
    Paul
    Editor
    I was thinking check timing too.
    You might also go progressive with the linkage,
    might be too much air/fuel at once for the little motor.
  13. sdluck
    sdluck
    Block off each carb and test run it. see if it is one of the carbs or something else
  14. rodderbilly
    rodderbilly
    from italy
    yes Pete carbs are rebuild...only i notate that the accelerator pump link has some play in the middle position(2)....the hole on the plate is a little large...i try to remove the dual carb linkage and see what happened playing on each carb....
  15. KENDEUCE
    KENDEUCE
    X2 on timing. Cured my stumble by increasing the timing.
  16. rodderbilly
    rodderbilly
    from italy
    i have played with the timing time ago and the cars likes increasing the timing....today i drive the car with only one carb and the engine rev up well....
  17. Other carb delivers air but not enough fuel.
    Accelerator pump would be a likely suspect.
    61klassic likes this.
  18. ROADSTER1927
    ROADSTER1927
    Did you just disconnect the linkage? You should pull one carb off and block the ports, get that running great the do the same with the other, then put them both on and adjust the linkage to where they are at idle. Gary:)
  19. rodderbilly
    rodderbilly
    from italy
    Yes Gary i just disconnect the linkage, i need to made a plate to block the carb port...now i was checking the carb squirts and i notate that one hole in the front carb squirt was clogged,i removed the squirter and clear all with carb cleaner and air....i replace the squirter and moving the fuel pump level i see that fuel comes out from the 2 squirter holes now....Tomorrow i try first to see if was the squirter that made the problem than i try to block the ports on one carb....
  20. tommy
    tommy
    Not a good sign for supposedly rebuilt carbs:D That surely will cause it to bog.
  21. rodderbilly
    rodderbilly
    from italy
    after the drive with one carb (was the rear carb)....i check the front carb how works moving the accel pump lever and i have seen that from one hole of the squirter don't came fuel when i pump...so i removed the squirter clean it and now fuel came from the 2 holes.....Tomorrow i see what appened...:cool:
  22. Baumi
    Baumi
    I think you´ll find the problem around the accelerator pumps, the backfires also indicates a lean condition when you open the throttle..
  23. rodderbilly
    rodderbilly
    from italy
    i think the same.....Tomorrow i see if the engine replies good..if not, i try to block one carb ports..if the engine runs well with one carb i'm thinking to change main jets from 51 to 49 or 47.....
  24. rodderbilly
    rodderbilly
    from italy
    Ah.....thanks all for support and help.. hamber friends!
  25. rodderbilly
    rodderbilly
    from italy
    problem not solved ....wasn't the squirter in the nozzle ...i order the accelerator pump from vintagespeed....
  26. 48-760
    48-760
    from OH
    You want leather accelerator pump and not the plastic. Check out the length of the oval hole in the accelerator pump rod and the total length of the rod. At one time the rod and hole were not of the proper length for many replacement pumps. You may want to check out Daytona carb parts and rebuilding kits.
  27. rodderbilly
    rodderbilly
    from italy
    Yesterday i block-off each carb....the engine is bad to idle i don't have very good results.....so i try to put a ballast on the +coil wire...i look for the conditions of the spark plugs ,they have only some hours of work and i try what you see in the picture..the central electrode is in bad conditions....so i put the old spark plugs...that in reality are not very old....and the engine now reply good....
    upload immagini
  28. ROADSTER1927
    ROADSTER1927
    Glad you are getting somewhere! Again tune it with on carb blocked until PERFECT, then block that one and tune the other until PERFECT! Then adjust the idle with both until it all works!
  29. hotrodderhaag
    hotrodderhaag
    make sure you dont run champion spark plugs... my flathead was a tuning nightmare till i yanked out the champion and bought motocraft SP473's for in it,
    much better!!
  30. rodderbilly
    rodderbilly
    from italy
    Hi hotrodder....i'm running ngk b-6l plugs....only one time i use the champion h10 but i prefer the ngk....
