Projects Flathead Ford Transmissions
Discussion in 'The Hokey Ass Message Board' started by Spencer Caldwell, Sep 27, 2017.
  1. Spencer Caldwell
    Spencer Caldwell
    Somebody help... i am doing a 59ab into a 30 sedan. I have a 8b transmission 3 speed with overdrive. Can that fit on my motor. Or does anyone have any ideas instead of a t5 conversion or aod. Thank you so much.
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  2. You will need a bellhousing adapter or the "hogshead" from a '40's truck.
    LOU WELLS likes this.
  3. The 39 guy
    The 39 guy
    Here is another option if you can find one the 49-50 Mercury trans bolts right up to the 59 series block
    LOU WELLS and j-jock like this.
  4. 55styleliner
    55styleliner
    IMG_0148.JPG I used the mid-80s Ford RTS Transmission
    LOU WELLS and Texas Webb like this.
  5. Koz
    Koz
    Is that a Wilcap adapter on there?
  6. I'd also like to know^^^^^^.
  7. rhtfo
    rhtfo
  8. King ford
    King ford
    from 08302
    Wyatt is a RTS transmission out of Styliner?
  9. 51504bat
    51504bat
    My guess is that its from Model Engineering (MEC)
  10. 55styleliner
    55styleliner
    Yes it's the Model Engineering adapter.
  11. 55styleliner
    55styleliner
  12. I used the MEC adapter at first in my 8BA powered '35 sedan with a 3.55 rear. Really a 3 spd + OD in 4th. I didn't like the ratio spread in the gears and needed a lower 1st gear so changed over to a T-5.
  13. 55styleliner
    55styleliner
    There is a big jump from second to third and another big jump from third to fourth. But it's at the sacrifice of having the shifter in the right place
    Spencer Caldwell likes this.
  14. Would it be better with 3:78 rear gears?
    And the rts trans comes in 2 different ratios,a close and wide,Which is better?
  15. 55styleliner
    55styleliner
    RTSDecodingTable.jpg There are actually 3 different ratio sets in the RTS transmissions. Mine has the tallest overdrive gear of .70. I have 3.78 rear gears and 7.00 X 16 rear tires. That all translates into 2000 RPM at 70 MPH. Ideally I would try to get the .78 overdrive version. So, to get e little more RPM at 70, I have a set of 4.44 gears I am going to swap in, but my first and second gears are about right now. I don't think the 4.44 wont have as much affect on the final drive ratio in first and second as it does on the overdrive.
    Spencer Caldwell and larry k like this.
  16. 55styleliner
    55styleliner
  17. Thank you,I didn't type in enough letters.
  18. Spencer Caldwell
    Spencer Caldwell
    I got myself a hogshead adapter for 80 bucks... i think i am going to run the t5 ford. I read good things about this execpt the shifter location is further back
  19. That can be fixed with an 80's s10 tailhousing,or use an s10 t5.
