Flathead ford spark plug choice
Discussion in 'The Hokey Ass Message Board' started by gearhead695456, Sep 5, 2013.
  1. gearhead695456
    gearhead695456
    I'm running a flathead 8BA with aluminum Edelbrock heads. I am wondering what sparkplug might be the best choice for this set up. I[ve been told that the champion #271RC12YC would work but Im also running an Isky Max 1 cam and dual Stromberg 97s. Any input? Thanks.
  2. hotrodderhaag
    hotrodderhaag
    dont buy a champion, back in the day they were great... now they are terrible.. my flatty hates champions. i run NGK's in mine and also autolites/motocraft.. i cant remember the number off hand though
  3. txturbo
    txturbo
    Champions only seem to work well in lawn mowers these days. I stopped using them for anything else back in the early 80s. Unless you can find some NOS ones I would use some other brand.
  4. hamz52
    hamz52
    from so cal
    I have virtually the same set up only I have holley 94s. I use the NGK BL 6s.
  5. gearhead695456
    gearhead695456
    Thanks the NGKs seem to get the most votes. I was told the plug has to clear the aftermarket heads but this may or may not be an issue.
  6. Feo
    Feo
    I've ran champion sparkplugs HC 10 since 07 till today. I haven't had any trouble with them. Maybe its just good luck..But the heads on the 39 are stock..
  7. 40FordGuy
    40FordGuy
    Yes to NGK; H10 is also too short a reach, to put the electrode onto the combustion chambers. Be sure to check that, and NGK has correct reach plugs close to the H10 heat range.
    Happy Roddin', 4TTRUK
  8. hombres ruin
    hombres ruin
    Autolite 216s are perfect length for aluminum heads.Its what i have used and it runs perfect
  9. 40FordGuy
    40FordGuy
    Thanks......I'm adding that item to my info book.
    4TTRUK
  10. Autolites are now made in China
  11. Don Lyon
    Don Lyon
    NAPA, get equivalent plug in NipponDenso, lasts forever.
