Technical Flathead Distributor wiring
Discussion in 'Traditional Hot Rods' started by flathead48, Jan 29, 2012.
  1. flathead48
    flathead48
    I have a 1940 ford and i am using a 42-48 distributor with a external coil. I need to which wire from the coil goes to the distributor. If someone could help me with the wires that go to the coil and then to the distributor that would be great. I have switched over to 12 volts and negative ground.
    I just need a basic wiring diagram for the ignition.
    thanks alot
  2. Hot Rod Nut
    Hot Rod Nut
  3. 48 Chubby
    48 Chubby
    Distributor to neg side of coil.
    Pos side of coil to ballast resistor (if you're useing one)
    Ign terminal on switch to ballast resistor.
    This is greatly simplified, but should get you started.
    HRN types faster than me............use the van pelt link
  4. BJR
    BJR
  5. flathead48
    flathead48
    Thanks for the help i think you've all helped me solve my problem
