Hot Rods Flathead Cam Advice Please...
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Apr 16, 2020.
  1. Fortunateson
    Fortunateson
    I was over at the Ford Barn and received a strong recommendation to use a 8CM cam in my flathead which will have three 97s though I may block two off, Eddie Meyer heads, Merc crank running through a '39 trans with LZ gears into a '40 rear end with a 3.78.
    I was trying to decide between a EAC-a, the 8CM, and a Max 1 clone. Can anyone offer the pros and cons of each cam, some comments were that the EAC-a and the 8CM were basically the same.
    I'm going to be generally cruising and the occasional highway jaunt. A little rumble at idle and good torque with decent gas mileage(if that's possible!).
    town sedan likes this.
  2. fullhouse296
    fullhouse296
    from Australia
    Weight of vehicle is very important .If its a sedan ,just stick with a 5T cam out of a truck .
  3. Fortunateson
    Fortunateson
    Oops, I forgot to mention it will all be in. '32 5W.
  4. town sedan
    town sedan
    Bump back to page one because I'd like to know too.
    -Dave
  5. Fortunateson
    Fortunateson
    As Pink Floyd sang, "Is there anybody out there....?".
  6. Fortunateson
    Fortunateson
    What's happened to the HAMB brain Trust???p
  7. AngleDrive
    AngleDrive
    from Florida
    My choice would be a L100. It has alot of overlap so it needs good compression, like 8.5.
  8. T&A Flathead
    T&A Flathead
    I don’t have any experience with the cams you mentioned but I really like the Isky 400jr and Winfield SU1A cams. My isky is in a T roadster in a 50merc motor, good rpm range. My Winfield is in my 32 5w but only a 221 ci ‘40 motor.
  9. flatjack
    flatjack
    All 59A cams had 5T on them. Cars and trucks were the same. I have checked a number of V-8 cams, 8CM's are consistent. I have checked cams marked EA and EAB. Some have .330 lift (same as 8CM) and some have .300 lift. No consistency.
    town sedan and Desoto291Hemi like this.
  10. fordf1trucknut
    fordf1trucknut
    18620208_10213258787403691_1546483319251072525_n.jpg I run a max 1 in my 265 CID 8ba in my coupe and it runs very strong. I can actually hang with and pass the ohv cars on the dirt track!!!
    I have taken the car on some 3 hour one way trips and it has nice road manners as well.
