Flathead air compressor???
Discussion in 'The Hokey Ass Message Board' started by tattooedup37, Jan 27, 2007.
  1. tattooedup37
    tattooedup37
    I have the oppurtunity to buy an original kit to convert a 1937 flattie nto a compressor. I have heard of these where 4 cyl. are firing and the other 4 are actually compressing. This kit makes the whole engine a compressor and I have know fuckin' clue how? Does it use an external power source or what. the guy has no clue HELP
  2. flathead okie
    flathead okie
    oops. nevermind. ididn't read it right the first time.
  3. tattooedup37
    tattooedup37
    Ya I know. I said that. With this setup all cylinders compress?
  4. tattooedup37
    tattooedup37
    no problem hahahaha
  5. Big Dad
    Big Dad
    Not all 4 .. I seen ones that use 4 holes ?
  6. Svenny
    Svenny
    Sounds like one of those Popular Mechanics projects from the 50's.
    You might try a Public Library that has a good periodicals section.
    You'd be surprised how helpful a good librarian in a large library can be!
  7. tattooedup37
    tattooedup37
  8. chopperkid13
    chopperkid13
    i would buy the kit...just for the intake...hmmmm turbo?
  9. rodrelic
    rodrelic
    Probably worth some bucks just for a investment. O had a rental I maintained whileour rotary was being overhauled. Was a 460 ford, one side had plugs and ran like a motor. The other side had lines with check valves in lines that went to the tank. Oversimplified, but block the intake so as to eliminate the fuel from the air...
    And a different cap to insure the spark fored allm 4 cylinders...
    Crude but works, and that kit is a keeper not because it is efficent or practical nowdays but because it's histoirical...
    and someone wants it, so it.s trade stock for hot rod parts.
  10. Casey
    Casey
    I wanted to do this with a v8 60 ? buy it and post some pictures ! how mutch is it ? hell I will buy it . if your not going to! pm. me if your not going to buy it . Casey.
  11. fab32
    fab32
    I had a flarthead air compressor in about 1968 that was built by a company named Schramm. 4 cylinders compressed the air and 4 cylinders powered it. I believe Schramm is still in business, at least they were a few years ago. They made a lot of them in later years out of 6 cyl engines, 3 for power and 3 to compress. All of the construction air hammers you see at road constructions jobs are powered by a compressor of a similar type.
    Frank
