Flathead 2 x 2 offy
Discussion in 'The Hokey Ass Message Board' started by qmdv, Nov 19, 2012.
  1. I have a 2 x 2 offy without the generator mount. What was the reason for that option?
    It is in really good shape but will not work for my ride. Do you notice wood stove with drain oil drip in background? I recycle.:D
    Tim
  2. the generator hit front carb so it wasn't needed, offset mount used
  3. That is called a Super Dual.
  4. Mike51Merc
    Mike51Merc
    I have a couple of generator side mounts. PM me if interested.
  5. I need to mount a fan on the front of the manifold and the generator on the side using a generator mount. I have a gen mount already. I should sell the Super Duel for a super deal.
    Tim
  6. V8 Bob
    V8 Bob
    Early ('32-'48) Edelbrock super duals, and probably other makes, came with and without the front mounts. You'll find them at swap meets, online autions, etc. :)
  7. newrider3
    newrider3
    You get better fuel distribution with the wider spaced carbs, but lose the stock gen mount. If you check out the January '13 issue of Hot Rod, they have a flathead intake shootout, and by their results you net about 10hp on the top end with a 'super dual' spaced intake vs a narrow spaced 2x2.
  8. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    you can always use this mount that bolts to the front if you want to run the independent fan in the center. you can also use a slingshot bracket and put an alternator up front too.
  9. Bruce Lancaster
    Bruce Lancaster
    The ones with no bracket are for '39-41 cars which did not need it...fan was on the crank and so after you moved the generator over you were done. They were also common on racers before cheap stroker kits and huge displacements obsoleted the dual for high end engines. You need the bracket for about anything else so you can work a fan into your short..
    Better to buy only ones with brackets!
  10. daddio211
    daddio211
    Also, a number of manufacturers made heads with generator mounts on them. My Offy Super Dual intake is matched to my Offy heads on my 8BA. See the "nubs" on the top?
    At least I THINK that's what they're for!
    Sent from my DROID device using the TJJ mobile app
  11. V8 Bob
    V8 Bob
    The only "nubs" I see are ar the rear of the left head, and are oil filter mount boses. :confused::)
  12. daddio211
    daddio211
    Damnit, you're right. Small photo on my phone, bad memory on my part. :eek:
    Okay, I need the same help as the OP. What, where, how to mount the fan and generator???
  13. It is sitting on a 59AB. Will it also work on a 8BA?
    Tim
  14. daddio211
    daddio211
  15. canyonrods
    canyonrods
    from SoCal
  16. canyonrods
    canyonrods
    from SoCal
    Where can I get this mount?
  17. WTF really
    WTF really
    I love super deals.
  18. Jimmy2car
    Jimmy2car
    from No. Cal
    Many of those types of manifolds were also used in boat applicartions
  19. tubman
    tubman
    "daddio211" - Yep those are for 8BA's. The early ('48 and earlier) generator mounts bolt to the heads using longer studs. You notice there are left-handed and right-handed versions of those mounts. You should do a little planning and maybe even some mock up before you decide which one you need. Remember, the 8BA distributor is on the right front (passenger side) of the engine.
