My 50 flathead had a loose dipstick mount so I pulled the pan today. The mount rivets had been drilled out and machine screws put in with nuts on the inside of the pan. The nuts vibrated loose. Will nyloc nuts and some locktite work to secure the mount? What is the recommendation for this? Thanks, Don
Weld them. Or whack the threads with a center punch. Or wave locks. Posted using the Full Custom H.A.M.B. App!
Make a 1/4 steel triangular plate to match the boss and drill and tap it place it inisde the sump using a quality sealant and sandwich the lot together job done.
I bought this kit several years ago. I don't remember where I bought it. But making a plate like this as Kiwi 4d suggested should work well.
Thanks all! Lots of good ideas and options. I even thought about a small plate with PEM nuts pressed in. What's the recommdation on pan gaskets and seals?
