FIX:Master cylinder pushrod too short
Discussion in 'The Hokey Ass Message Board' started by sapple89, Jan 23, 2014.
  1. sapple89
    sapple89
    from SOCAL
    My push rod is about 4" too short. I was thinking about cutting a 4" bolt and stick it in the master cylinder. Can anyone think why this might not be a good idea?
  2. drptop70ss
    drptop70ss
    from NY
    As long as you are driving in CA and I am in NY I see no problem with it at all. The people you potentially kill when you brake pedal jams may have an issue with it.
  3. fsae0607
    fsae0607
    It is not a good idea because brakes are a safety item and you never mickey-mouse it. Get the right pushrod, or cut down a longer one.
  4. Gene Boul
    Gene Boul
    If you are willing to do that I would like a picture of the rest of the car!
  5. blowby
    blowby
    from Nicasio Ca
    Should work about as well as this
    GTO_MUSCLE_SS likes this.
  6. sapple89
    sapple89
    from SOCAL
    Maybe this will help......
  7. fsae0607
    fsae0607
  8. chubbie
    chubbie
    four inches is a lot, but I've made many brake push rods (almost every car i've built) is it a strait push? if its not you have to many things going on at one time. Use ..maybe a grd 5 or better bolt that looks right. weld ends on. i try to make them adjustable useing the treads on the bolt. If you have the skills to do this it's a no brainer
  9. saltflats
    saltflats
    from Missouri
    So the master is not the correct one for the booster.
  10. unkledaddy
    unkledaddy
    For all you naysayers.......I am currently using a bolt with a heim on the threaded end for adjustability on a manual system. I've had no problem whatsoever in 6 years.
    I cut the bolt to length, chucked it up in a drill and rounded the MC end on a belt sander.
  11. honeyman
    honeyman
    from Steiner
    There's a pill for that right?
    Sorry, couldn't resist...
  12. Looking at your pic brings to mind a couple safety-related items.
    1) lose the power booster. Given it's size, it's as likely to work as my wife's dog. Which is also small...And that may make up all you are lacking in rod length.
    2) I hope that firewall is braced on the backside, because the utter lack of bracing on the engine side means that the brake master will be bending the firewall, to the point of fracturing. And you may be surprised how quickly, as well.
    3) Do not try filling the master with a bolt to make up for lack of rod length, the real danger is that the pushrod might fall out, leaving you with no brakes.
    Cosmo
  13. fsae0607
    fsae0607
    I was referring to the two-piece rod idea that is unsafe. A MC rod should be one-piece. Just want to be clear about that :)
  14. primerhotrod
    primerhotrod
    from ILLINOIS
    Now that thing just screams traditional.
    Different length adjustable push rods are available. Sumit or Jegs has them, and from the pic shown, you def have one of their catalogs.
  15. classic gary
    classic gary
    Which one is short? The one from the pedal to the booster or the one from the booster to the master. If the latter, then you've got the wrong master cylinder, if the former, Speedway has a nice kit with lots of parts for lots of adjustability.
  16. nunattax
    nunattax
    from IRELAND
    thank god im surrounded by water
  17. badshifter
    badshifter
    Nope...
