Projects First time build ........ aka Beaver Creek Coupe
Discussion in 'Traditional Hot Rods' started by baspinall, Apr 24, 2018.
  1. Get to know your welder,
    Some have a cold start ramp up on voltage. If it has that it will be cold at the first pull of the trigger then ramp up quickly. That's useful for filling holes and such by tapping the trigger, but will quickly blow a hole once the ramp up happens if your still holding the trigger. The cold start ramp up needs a higher setting for tacking too.
    50 customcoupe likes this.
  2. sloppy jalopies
    sloppy jalopies
    I like .030" as it supplies more filler... IMO... the wire burns hottest away from the nozzle, I try and keep my past weld in that spot while I work my way along the gap, branch to the sides but quickly cheat back to the safety of the past weld...
    I have tacked some scrap strips of .030" lengthwise down into the gap and worked from the loose end... they kind of held up the molten weld and worked as filler... hope that doesn't give flop heartburn ?
  3. indyjps
    indyjps
    Did you pick up a liner and tips for .023?
    An air saw is nice to have in the box to get into tight spots, sometimes even the small diameter cut off wheels dont fit. Another approach is to drill the corners of your patch area with a large diameter bit and put radii in the patch corners. You will maintain metal thickness and not have the cut off wheel "overcuts".
  4. baspinall
    baspinall
    from SE PA
    Dang! Nope. I know the tips but didn't know I had to change the liner?
  5. baspinall
    baspinall
    from SE PA
    As far as the tooling goes. Don't think my 20 Gallon Craftsman will do the job with the air tools? I know it has issues with the little air sander I have. I'll give a look at the air/elec. saws.
  6. Stooge
    Stooge
    you could probably use an air die grinder, it would just be slow moving and would have to let the compressor catch up, but if there are smaller electric ones that are maneuverable/ not too clumsy, they will come in handy for smaller cut off wheels, roloc sanding pads, etc.
    I typically use .030 wire for most everything I do, sheet metal and the thicker stuff, it works well for me and is what I am used to and I don't have to bother swapping out wire. I might have missed what welder you have, but check with the drive roller/wheel inside where you load the wire, there should be compatible wire sizes on there with accompanying grooves for the wire to sit in, as you may need to pick up a new one of those as well if stepping down in sizes.
    Definitely pick up some small strong magnets, I like the small circular ones as opposed to the big red arrow ones usually, but both are handy, and the arrow ones are good for making stuff when you need perpendicular/ angles, etc. the small butt joint/ panel intergrip clamps,( I know they atleast sell them at harbor freight) are good if you can access the backside to get the block out, but the thickness of part of the clamp can make for a larger gap and that can be a pain. I use a lot of clecos and cleco style side grips, nice and quick and hold strong.
    http://www.aircraftspruce.com/catalog/topages/sheetholder.php?clickkey=3620
    http://www.aircraftspruce.com/catalog/topages/clamps1.php?recfer=4430
    Something I like doing for butt joints on sheet metal, are making short little links to cleco pin together, takes a little longer, but is really handy for hard to access places, not the best picture, but this is the idea. just little pieces of scrap with holes drilled in them
  7. baspinall
    baspinall
    from SE PA
    The welder I'm using is a Miller 211
  8. Stooge
    Stooge
    That's the machine I primarily use, are you using the autoset feature on it? i dont generally use it, but I've noticed that when using that instead of dialing it in by hand, it runs a little hot and fast for my liking on sheet metal, especially old contaminated/rusty sheet metal, could be part of what is causing you to burn through.
    Bandit Billy likes this.
  9. baspinall
    baspinall
    from SE PA
    Ive been trying both. Yes it does seem hot on auto. On regular I would dial down the voltage a tad correct?
  10. Stooge
    Stooge
    I want to say for sheet metal, I usually have the voltage knob set to around 2.75 give or take a 1/4, and the wire speed at or a little under 30 or so but i'm always playing around a little, and gas flow around 15. this is also for about 18gauge sheet metal, thinner stuff, turn both down a hair.
    baspinall likes this.
  11. 1946caddy
    1946caddy
    from washington
  12. 37 caddy
    37 caddy
    from PEI Canada
    What i use for a copper backer is a piece of 1/2 copper pipe,same stuff they use for household water lines,it is about a foot long,on one end i pound it flat like a spoon?,that way i have a handle to hold it in place when im trying to fill holes,works good and when it is all used up i just make another one.I sometimes use the welding magnets to hold a patch in place,they are available at places like harbor freight pretty cheap,they are all kinds of shapes,some bigger then others,but they will all do the job. Patching old cars is not easy so keep trying and dont give up,maybe walk away for a bit,then try it again. Harvey
  13. rnscustom
    rnscustom
    I think you only need change the tip , liner should be fine . Question on magnets . I heard the magnet affects the weld ?? Maybe only on tig ?? Restoration friend only used .030 and all his welds look good . My son switched out the .023 for .030 and likes it better , less blowouts .
  14. Stooge
    Stooge
    I notice if i get a little too close( within 1/4" or so) to some of the really strong magnets, it will sputter a bit and feels like its grabbing or something, i notice it less with the big red arrow ones sine they are weaker.
  15. AldeanFan
    AldeanFan
    The magnet can pull your puddle towards it and distort your weld
    I’ve heard not to put a magnet between the torch and ground, don’t know why and never tried it.
  16. 1946caddy
    1946caddy
    from washington
    I sheared some 18 ga. copper and made a bunch of these with different handles to reach in behind panels.
  17. 6sally6
    6sally6
    YAAAAAAAA!!!! I posted a picture!!!!!!!!
  18. rnscustom
    rnscustom
    Great video , this guy is so calm and relaxed . Makes you want to dive right in it looks so simple ( AMD tech guy I think )
    chargin03 likes this.
  19. southcross2631
    southcross2631
    Harbor Freight sells a copper paddle for less than 10 bucks. I have been changing back and forth between .023 wire and .030 wire for 20 years without changing a liner . Just the tips. Maybe I am doing it wrong ?
    I always coat the back side of the patch and the surrounding area with weld through primer available at Napa auto parts. Keeps future corrosion from rusting my repair.
  20. Halfdozen
    Halfdozen
  21. baspinall
    baspinall
    from SE PA
    OK so on my other A pillar the bottom portion is really bad. I bought a donor pillar that is tweaked at the top. Would you guys cut the donor as low as needed or use as much of it as possible? Or does it even matter? I was thinking just cutting the bottom portion would be best. Retaining the structure of the original.
  22. Aaron D.
    Aaron D.
    If it were me, I would replace just what's below the hinge.
    Aaron
    warhorseracing likes this.
  23. baspinall
    baspinall
    from SE PA
    Aron, that's what I was thinking.
  24. Mechman_22
    Mechman_22
    from Nc
    I'm doing the same thing with my b pillar, but I don't have replacement so have to make it
  25. baspinall
    baspinall
    from SE PA
    Mechman_22 - I'll be making the bottoms of my B Pillars as well.
  26. baspinall
    baspinall
    from SE PA
    Update - I cut my donor A pillar today. I have a question about removing the corner/triangle sub frame bracket. Drilled out the rivets and spot welds but still can't get this bracket out? I don't want to bend this piece up trying to get it out but there is a lot of rust and dirt behind the bracket. Went at it a bit with a chisel and hammer and it not budging. Would like to clean it up before I weld it to the pillar.
  27. baspinall
    baspinall
    from SE PA
    Well I got that sucker out finally!
    31Vicky with a hemi likes this.
  28. baspinall
    baspinall
    from SE PA
    Well I received some of my roof tin back from the media blaster the other day. Most of my roof pieces are ok. My drivers side rear window quarter has a lot of pin holes in it which will have to be addressed. I do have a donor window quarter so I may use that.
    One question I have is when you guys put these pieces back together do you add a welting strip or anything in between the pieces being bolted or do you just bolt metal to metal?
    My quarters will go to the media guy next. I also realize that I probably should not have had him epoxy primer these since I have a bit of metal work to do still. What is the best coarse of action to prevent rust when items come back? A different type of primer?
  29. baspinall
    baspinall
    from SE PA
    Another question on the welding end of things. I was talking to Bob Moon my media blaster guy and he advised me to use my welder hooked up to the 220V all the time. He said even with small wire patches and such they run with a much better arc on 220. Is this true?
  30. baspinall
    baspinall
    from SE PA
    Today I got on B pillar foot made and welded in. Also pie cut the front sub rail cowl brace to fit better. Small steps .....
    Stock Racer likes this.
