First car build, 1930 Model a Sedan
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by Gezkeni, May 13, 2020.
  1. Sure, Its your car
    0 vote(s)
    0.0%
  2. No and here is why
    0 vote(s)
    0.0%
  3. If you are really that into yard work I suppose
    0 vote(s)
    0.0%
  1. Gezkeni
    Gezkeni
    I bought my first car to start tinkering with, My son has been out and helped me ( as much as a 4 year old can with his plastic tools!) He gets just as excited as I do about going out to the garage to work. Currently, the body is going to stay the way it is, with the exception of structural things that need to be addressed.
    I have been doing some digging into the car,
    Things I'm certain of
    The engine is 350 from a 70's C30
    Turbo 400 trans with TCI torque converter
    Briggs body
    Things I think it may be,
    original frame ( see note below about the school)
    37 front spindles ( possibly the entire front assembly)
    Trying to Identify the rear axel
    Story goes
    This car ( frame and body) may have been originally chopped and built by a school in 1969. So I have to assume things on it were done with what they had.
    First Steps,
    1. I have disassembled the front spindles, cleaned, prepped for new bearings and king pins.
    2. Purchase disc brake conversion
    3. I have C channel Boxing plates from Code504 http://www.code504.com/the-boxer-1928-1931-model-a-inner-channel-boxing-plates/
    4. Cut off the old ( bubble gum welded ) 4 link and rebuild with better quality.
    cut off all the added stuff to the frame for a fresh start
    5. once its boxed get the engine trans in approximate location to weld in motor mounts and trans mounts
    6. get all the brackets in place for rear 4 link
    After all that,
    1. Steering ( i think it was originally set up for cross steer?)
    2. find the best way to mount the body to the frame
    3. mount brake pedal assembly
    4. figure out floor situation
    I'm sure there are 10000 other things in each one of those categories but working on strengthening the frame for now and make it solid to the wheels.
    96234618_672501580203438_4210660407989239808_n.jpg 96377517_1367432083467288_5259284898170011648_n.jpg 95830103_555304998736508_4994628008368144384_n.jpg
    rbrewer likes this.
  2. slv63
    slv63
    Best of luck with the project! What are you thinking to do about the firewall? I wonder why someone did that?
    rbrewer likes this.
  3. Gezkeni
    Gezkeni
    I'm not sure unless it was bad.. or the plan was to move it further back? I'm on the hunt for one, doesn't need to be great as I'm going to have to cut it up to fit trans.
  4. Gezkeni
    Gezkeni
    Dry fitting the boxing c- channels. Had to tickle the frame a little bit but so far so good. 20200515_053040.jpeg
    Sent from my SM-G955U using The H.A.M.B. mobile app
    rbrewer likes this.
