Hello, I Would like your Experienced thoughts on what GUAGE of Steel should be used for a RECESSED Firewall. 14 , 16 , 18 thickness ?? What would you use? and How have you made yours? Thanks ..
Firewall should be a minimum of at least 18, no lighter since it helps strengthen and deaden sound as act as a barrier agianst engine heat, noise, fire(should things get exciting). Me, I'm into the math thing, I'll layout pie cuts and heat marks, whup out my plasma and rosebud and go to town, then I finish up with a little teasing with a 5 lb. drilling hammer, some tnder loving care with the deadblow, and finally the romantic stuff with the dollies and a english wheel or planishing hammer.....whichever the mood calls for!
Here is how I built mine. Says 10ga but its actually 12..... I shouldve used thinner material and deffinitly would not have hesitated to use 16-18 if I had a beadroller at the time. http://www.roddingroundtable.com/tech/articles/firewall1.html
I used 18 gauge for my firewall. I had 16 gauge but opted for the 18 gauge for ease of cutting/bending.
Thanks for the Info.. Im Ready to start the one in the HENRY J.. any one out there with cars of the 50s Doing the same??
