Finned pontiac valve covers (prototypes)
Discussion in 'The Hokey Ass Message Board' started by 1954fordkustom, Oct 5, 2014.
  1. mgtstumpy
    mgtstumpy
    I don't even own a Pontiac and would love a set.:D
  2. GRX
    GRX
    from MD
    I'd put those on my '69 GTO :D
  3. Depending on how they're made they should fit all Pontiac heads. '65 or so they get a little longer, you have to silicone the ends a bit to use them on earlier engines - or so I remember, it's been a while.
    A matching valley cover would fit all of them too, at least some they kept the hole for the draft tube, it got a rubber plug and the PCV valve went there.
  4. retromotors
    retromotors
    If that's the case, why do the Y block valve covers on your site cost $280 - $300 ?
    Is there really that much of a difference in their construction?
    Just curious ....:cool:
  5. 1954fordkustom
    1954fordkustom
    Retro motors. The y block cost that much due to the fact I started with all new inner and outer tooling. Now with the pontiac valve the inner mold that was already available to me. There for the cost is a lot less since we had pre existing tooling available
  6. retromotors
    retromotors
    OK, I gotcha. Makes perfect sense.
    Thanks for the response, and good luck with your endeavors.
    Retro
  7. rustisgold
    rustisgold
    Any availability dates? And are they or will they be tall enough to clear roller rockers?
  8. There is a difference in the valve covers between the 55 thru 59 and the later 326 thru 455 valve covers. Late covers on early engines will leak at the corners
  9. oldsrocket
    oldsrocket
    definitely cool. hope you are able to make the sales that you want. Pontiac guys are a special breed and most are "numbers matching" or nothing. I think that is why a lot of pontiac speed equipment is always so plentiful and cheap. In any event, as a lover of things pontiac and not a numbers matching weenie, I dig the covers and will definitely be watching for when they come available.
  10. You hit that one out of the park!
    Wish you made a similar for a centerbolt SBC or a perimeter bolt SBC. I'd be begging on bended kness for a set.
  11. wvenfield
    wvenfield
    Where in the world are you finding this plentiful and cheap Pontiac speed equipment? I want some.
  12. Atwater Mike
    Atwater Mike
    'step out of the box'... reminded me of a pal of mine in Paso Robles, 1965 or so. He had a pair of Cal Custom finned covers on his SBC in his '31 roadster. They got replaced with a pair of Morosos and hung in the barn. I asked about 'em, but when I went back to his house his Dad had 'em nailed to the porches, front and back.
    Made perfect mud scrapers for Pop's boots...
  13. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    I seen your Y block and Chev. ones at GNRS. I like the Chev. ones, hope you start production on them.
  14. 1954fordkustom
    1954fordkustom
    Hollywood graham thank you. The pontiac valve covers are ready. I'm just waiting for them to get processed through the warehouse then I can pick them up. We our shooting for our sbc to be here with in the next month.
  15. As mentioned by others there is a slight difference between the early and late covers which do these actually fit? thanks
  16. ClassicDriver
    ClassicDriver
  17. apparently they will only work on the later heads. if they fit the early heads if OP needs to clearify.
  18. 1954fordkustom
    1954fordkustom
    They will fit 59-79
  19. 1954fordkustom
    1954fordkustom
    They are finally here. I will be picking them up next weekend. I will post them for sale once I take inventory. Let me know if your still interested
  20. interested..........
  21. draggin'GTO
    draggin'GTO
    These custom rocker covers will fit all Pontiac V8s from the very first 287 built in 1955 all the way to end of production in 1981 when the anemic short-deck 265/301 economy engines were all that were left.
    The only issue is the early factory valve covers are shallower so the '67 and later valve train won't clear them, the later rockers will dent the early covers unless you use a spacer to raise up the covers.
    The valve angle changed from 20 degrees to 14 degrees in 1967, this was a transition year where the high-performance big-valve heads had the new 14 degree valve angle and the low-performance heads still retained the older 20 degree arrangement.
    A deeper aftermarket cover is going to fit all of the '55 -'81 Pontiac V8s with no issues. The same valve cover gasket was used from 1955 -1981, there are no issues sealing them no matter what year head you put them on.
  22. flamedabone
    flamedabone
    Still in. Let me know when you are ready.
    Thanks, -Abone.
  23. creepjohnny
    creepjohnny
    from Sunland,CA
  24. GetSome
    GetSome
  25. 1954fordkustom
    1954fordkustom
    Ok guys pontiac valve covers are now available. Hit me up if your still interested.
  26. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Do we have a final cost for those ultra cool valve covers?
    KK
  27. 1954fordkustom
    1954fordkustom
    Koolkat-57 they are $200 plus shipping
  28. clem
    clem
    Something different and refreshing. Fantastic!
  29. 1954fordkustom
    1954fordkustom
  30. flamedabone
    flamedabone
    Shitty pic of some really bitchn valve covers. If you don't have your set yet, you better get on it.
    -Abone.
    kiwijeff likes this.
