Hey guys!!! So I have a 62 chevy rear end with the stock rear brakes. I have done some homework and found that the rear drums, 11 X 2, are pretty much used for ALOT of different years and applications. Some used on the front of 49-54 chevys, rears on different chevys into the early 70s. But what I would like to find are finned drums for this, as it will be seen. Not aluminum (but that would be cool) but cast iron would be fine, just want the finned look. Anyone know of an application I might check out??? My OT chevelle has them but they are 9" di. Thanks fore any help!!!
You are right about the bolt pattern, I forgot. I was trying to remember what Chevs I had seen in junk yards with finned drums and those came to mind.
Arent the stock eighties GM A and G body rear drums 11"? I know they are finned aluminum... Editoops! Nope, 9.5"!! PUNY! http://www.gbodyparts.com/product_info.php?products_id=1423
I believe the 60's GTOs has finned drums and were the same bolt pattern as the Chev (4.75 ) I have seen them on a Chevelle, not sure if the brakes were larger.
11x? but, 4 3/4 patternhttp://www.ebay.com/itm/NOS-84-96-GM-DELCO-REAR-BRAKE-DRUM-1244646-BUICK-CHEVROLET-CADILLAC-OLDS-177359-/261982820645?hash=item3cff649925:g:4g0AAOSwZkJUUZe5&vxp=mtr
The lug bolt pattern diameter is an easy fix if the drum otherwise has correct dimensions for your intended application. It's a pretty simple operation to drill or punch a new set of lug bolt holes in the spacing needed. Ray
O'Reilly Auto Parts and other major chains have an excellent on line part search system. Go there and enter the vehicle make and model....follow the prompts for type of part wanted, etc., and the illustrations will show key dimensions that matter in a search. If I recall correctly, you can just do a search of the type of part, without the make/model specifics. That allows a search of all the stuff they have catalogued. Ray
I have a set of finned aluminum drums that I think are 11 inch that can on the back of a mid 80's full size Oldsmobile station wagon. I'll measure them and take picks in the morning. I had them for years and never used them.
