Finally bought a Coupe, building a Banger!
Discussion in 'The Hokey Ass Message Board' started by FourBangNCanuck, Jul 20, 2011.
  1. search out Chris on the hamb also
    he had a bitchen 30 coupe that was not chopped
    hopped up b
    lowered front and back
    i think its on the other side of the pond now though
    tk
  2. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    Here is mine in the mock up stages. Its lowered and unchopped, looks good but it could use 3" gone.
  3. Elrod
    Elrod
    Took the coupe out today for lunch...
  4. BCCHOPIT
    BCCHOPIT
    very nice car to start with... Have fun with it
    Elrod you lost your fenders
    now I can see what mine will look like with a hair cut
  5. Hdonlybob
    Hdonlybob
    Cool ride, and great idea...
    Keep us in pics too!
    Cheers.......
  6. FourBangNCanuck
    FourBangNCanuck
    from ON, Canada
    This car is sick!
    What's your intake/exhaust setup?
    I really like the fenderless 3" chop look man!
  7. Granger Perry
    Granger Perry
    from Albany, WI
    Damn auto rats and there hot rods! Haha well have to go cruisin when school starts there Pete!
  8. chrisntx
    chrisntx
    from Texas .
    The best thing you can do for your engine is a high compression head.
    The best thing to made it fun to drive is a fully synchronised transmission with overdrive. I used a 84-87 F150 transmission, with my torque tube rear axle
    A dropped axle really looks good.
  9. rusthaug
    rusthaug
    Nice A, I think it needs a good chop :)
  10. Elrod
    Elrod
    The intake is an original Thomas intake for two Stromberg carbs. They make new ones, and both new and original ones pop up on ebay from time to time.
    I got a true dual exhaust from Reds Headers. It was cheap to begin with, but I didn't like the quality, so I had Bass TIG up each pipe where it went into the flange, and then when I had the exhaust done at a shop, they had to massage the fit quite a bit so that it would fit in the frame.
    Thomas High Compression head (Winfield profile), B ground cam, lightened flywheel and electronic ignition.
  11. FourBangNCanuck
    FourBangNCanuck
    from ON, Canada
    Well here is a September update
    The fenders and bumpers were pulled. Next came the body, interior and now the front suspension.
    Both front and rear shackle bushings are shot, transmission needs a rebuild, and my clutch is not great.
    However the engine has good compression so it will stay put.
    The plan is 32 heavy with reverse eye and maybe a leaf or two removed up front. Also reverse eye with a leaf or two removed in the rear (still want a good rake tho).
    The 35 wires are going for a powder coat next week then they will be mounted on new Firestone blackwall 550/700s shortly after.
    I have collected two beautiful BLC 682-Js with lots of patina, a Ansen dual downdraft, a old mallory off a combine (needs rebuilt) and a "B" cast police head for slightly higher compression.
    Trying to decide if I should go with '40 brakes now or not. My mechanicals worked but were very pieced together and I figure it will take more money/time than they are worth to get them right. If I convert I think I should go with 39 spindles at the same time. Im on a fence with that one.
    I still need a pair of Stromberg 81s and a exhaust setup for the banger.
    The chop will happen down the road when the body is back on and the stance is just right. I also need either a 39 banjo or 40 wheel. Does anyone know what it takes to get them to fit on a stock A column?
    Im pretty new at all this so any input is appreciated!
    Heres the pics
  12. So-cal Tex
    So-cal Tex
    You could always keep the pre-war theme going and do a dropped A axle with mechanicals like ElRod and me did...............and yes Ed "Axle Stewart did experiment with a few dropped axled before the war ( late '38-'39)
  13. SvenskeRod
    SvenskeRod
    Glad to see the Mustang storage sheds are still being used for this kind of thing. I think more cars get restored out there than in Templeton.
    I graduated in '03, best time of my life and I hope your loving it! The car looks great and your plans for it sound even better!
  14. just a 33/34 axle swap for me
  15. HotRodHighley
    HotRodHighley
    from cincy, oh
    Looks great. I love the 5" chop on mine. A little hard to see stop lights, but great otherwise. Don't listen to anyone. Do what you want. Unless its something super rare, a car is never too nice to cut up. The nicer of a car you start with the nicer and easier it will be in the long run. Congrats and keep us updated!
  16. von birch
    von birch
    get your ass on the hamb and show off your new goodies! these folks are dying to see what you scored!
  17. oldsman41
    oldsman41
    yeah it does need a hair cut but 4 inches is plenty iam rather short and my friends car is cut 5 inches and it is hell to drive for him he is 6 feet tall but you do it your waythat is what is great about this hobby
  18. FourBangNCanuck
    FourBangNCanuck
    from ON, Canada
    hey guys, well after a lot of thought the banger has been put on hold. going to build that chassis next fall, found a beauty original 32 frame that i couldn't pass up and everything has changed. build thread has moved here
    http://www.jalopyjournal.com/forum/showthread.php?t=649772
    enjoy!
  19. BCCHOPIT
    BCCHOPIT
    Nice find on the frame... you might have to get a new user name:D
    Some day I will build a speedster out of my drive train
    good luck...
  20. abonecoupe31
    abonecoupe31
    from Michigan
    I was brought up as a restorer myself....my dad's influence. This was in '73 when I bought a rolling junker from my cousin Kenny McDonough for $25. No fenders, engine, radiator, wheels or interior. I had to get another body (channeled with a torch & never finished off) for $35. Used my grandfather's '30 Tudor frame (bought new and driven until '40 & replaced with a '34 5 window coupe that got him thru WWII~another story!) & hit every swap meet for the next 3 years. FWIW I was working on it Thanksgiving holiday in '74 when I was home from college~38 years ago. Drove it as my daily driver from '77 to '78 until I put a rod thru the block! repowered the following year with a '71 Ford Pinto 2.0L 4 banger which now powers my '28 Ford A Woodie.
    After dad died I did put together a chopped 2" '31 coupe that I pieced together from all of the coupe parts I collected~I saved one from the crusher! And I have been accused of "butchering" a Perfect Model A!
    There's a place for everything, stockers & rods. I appreciate both but have gravitated towards being a rodder. The other day I added up all the $ I have put into my A collection (4 coupes, 2 tudors, & one woodie) & came up with an average cost of less than $200 each as an initial cost. This doesn't include stitches, bandaids, replacement parts, etc. I'll never have another old car other than a Model A. Hot in the summer, cold in the winter, and a flat out BALL to drive! It doesn't get much better than this....
    Mark AKA "A-Bone"
    Abonecoupe31 on da H.A.M.B.
  21. 117harv
    117harv
