Technical Filling roof, 36 5 window
Discussion in 'Traditional Hot Rods' started by willowbilly3, Jun 8, 2017.
  1. willowbilly3
    willowbilly3
    from Sturgis
    What makes a good donor for a filler panel to close the roof on my 36 5 window Ford coupe? thanks
  2. sloppy jalopies
    sloppy jalopies
    Try using a length of wooden strapping,
    plot the arch and length of the front to back of your opening, mark and label it on one side...
    plot the arch and mark the length left to right of your opening, mark it on the other side...
    to do this, set the wood on the roof of your hot rod... measure and mark the distance between the roof and the stick where the gap at both ends are equal...
    repeat for the side to side measurement...
    ... Now take the stick with you to a junk yard, set it on the potential donar's roof, check both directions,
    if the gap between the donar's roof and your stick matches the measurements that you marked on the stick ends... buy it...
    Because the roof's skin was stamped into a compound curve it is forgiving as you can add or subtract a little arch without kinking...
    The opening in your '36 roof is small compared to a model A, I used a Mercury Sable roof turned 90* on my '33 5 window... ... hope it helps...
  3. gearheadbill
    gearheadbill
  4. manyolcars
    manyolcars
    I used a 66 nova for my avatar
  5. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Check my comment on the Ford barn.
  6. jimmy six
    jimmy six
    Don't do it....
    Rusk and RICH B like this.
  7. deucendude
    deucendude
    from norcal
    Why fill your roof?
  8. cretin
    cretin
    @sloppy jalopies answer is a pretty good one if you're junkyard searching. If you don't mind paying the cost for a craftsman to make you a new one, Walden speedshop sells the panel.
  9. willowbilly3
    willowbilly3
    from Sturgis
    So it doesn't get rain and snow inside
  10. willowbilly3
    willowbilly3
    from Sturgis
    Good tip, thanks
  11. I used a 61 corvair coupe top for my 34 ford. Was an old stock car with all the structure cut out of the original top.
  12. deathrowdave
    deathrowdave
    from NKy
    54 StupidBaker for my 32 3 window
  13. Mo rust
    Mo rust
    I used a pinto wagon for to fill my 32 three window. You'll be surprised how many tops actually will work. You just need something that is large enough, smooth and has at least an inch or more crown in the middle. Once you cut it out of the donor car, some of the crown flattens out so find one with a little more than you want in your coupe. I would rather have a little too much crown than one that is too flat.
  14. linechaser32
    linechaser32
    from Iowa
    70 Camaro turned front to back works well.
  15. eberhama
    eberhama
    The take away here is that most any low crown roof panel will do the job. Stay away from the late model tin can crap and you'll be fine. I used a chunk of '39 ford sedan roof because its what I had laying around.
  16. i used a `48 Tucker roof on a `29 Graham Paige sedan
    not sure how this helps
    scrubby2009 likes this.
  17. FalconMan
    FalconMan
    from Minnesota
    I used a 66 mustang fastback roof on my 36 3 window.... perfect crown.
    Sent from my SM-G930V using The H.A.M.B. mobile app
    Stormtron likes this.
  18. kb cookout
    kb cookout
    I have used Ford Pinto , Mustang II, Maverick, donor roofs for 35-36 Ford coupes
    later kb
  19. Walden Speed shop makes a nice one.
  20. nochop
    nochop
    from norcal
    I used a 59 Chevy hardtop on my 32 5er
  21. deucendude
    deucendude
    from norcal
    If you have a good original body, at least in Ca. it devalues the car. Everyone I know doesn't want a filled roof. Although it's your car do what you want. That's what hot rodding's all about, individual preference. Good luck on it.
    WiredSpider and TagMan like this.
  22. falconsprint63
    falconsprint63
    from Mayberry
  23. MAD 034
    MAD 034
    from Washington
    Think about taking the no fill route -- original hole in the roof makes it part of being an old Ford.
  24. cretin
    cretin
    I'm pretty surprised about the amount of opposition to filling a roof, not that he asked anyones opinion. It's nothing new.
    clem likes this.
  25. clem
    clem
    I am surprised at how many gave him advice to fill his roof based on the earlier models they have, - not the '36 he asked about.........
    cretin likes this.
  26. deathrowdave
    deathrowdave
    from NKy
    What ever you choose to use , never use a flat piece of stock ! You will never forget that you made a mistake . I had a friend that had a super nice 35 3 window , filled with flat sheet , ended up selling the car because he took so much grief , new owner covered it with newer , cover and moulding , it looked better but still not the look ! Just take your time skip around welding , hammer your welds and all will be as if it were there when Henry shipped it . Living in the mid west not filling a top is not on the option list .
  27. sloppy jalopies
    sloppy jalopies
    ... he didn't ask if... he asked how and what...
    perhaps ye west coasters ought spend the time you didn't spend filling your roof and take a literacy class !
    cretin and TagMan like this.
  28. DLRIDES
    DLRIDES
    from Newton NC
    The perfect filler is a insulated snap out cover. Open top when you want, dry and warm when you need.
  29. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Maverick skin. Walden makes a beautiful insert the will surely fit, but it's $500. You didn't say what your budget was and whether or not you were doing the welding or hiring out the task? Those two things figure into the bottom line. If you're hiring this out, the Walden skin may save a couple of hours of hired prep labor and any cost associated with the junk yard roof purchase, making the Walden insert price point more attractive.
    As for fill/don't fill controversy. It's your car, do what you want. I filled my 34 because I've always thought chopped cars look better with a filled roof. Plus the roof opening reveal had been butchered out of my roof (previous parts car?).
  30. Unless you know how to do all the work - start to finish, I highly suggest buying the insert from Walden. They are great people, their work is fantastic and you will SAVE yourself (or anybody doing the work) a LOT of time. They just made an insert for my 34 coupe (60's Comp Coupe type build) - really nice work at a very fair price.
