I need to fill and smooth a hole in an aluminum valve cover before painting. The hole is blind and is 3/16 diameter and 5/8 deep. I thought about using JB Weld. Anybody have good idea?
I saw an article in an English antique motorcycle magazine where the guy was restoring a 30s motorcycle. The cast aluminum clutch cover had 2 deep pits corroded into it. He drilled right through the pits and took pieces of aluminum rod the same diameter as the drill. Peened them into the hole like a rivet. Filed, sanded and polished the cover smooth. When he was done it looked brand new. I expect he countersunk the holes just a hair to help the repair hold on.
Welding is always the preferred method, but a couple times I've done "quick and dirty" repairs on aluminum that wasn't practical to remove, weld or repair correctly. I used an epoxy similar to JB, but had aluminum flakes in it, so the color match was better, and a bit stronger.
