  1. NEW MERCH!!!!!!
    Hey guys... It's that time of the year again and we are introducing some new shirts in the Jalopy Journal store - including our first ever pocket shirt! So, if you are in the need for some new threads go here:
    The Jalopy Journal Store
    Dismiss Notice
Projects Fenton header clearance
Discussion in 'Traditional Hot Rods' started by 36 Penny Coupe, Jan 2, 2018.
  1. 36 Penny Coupe
    36 Penny Coupe
    from VA
    Working on my 36 Ford and the Fenton headers are not clearing the steering box. Engine is a 1950 Flathead. I do not know the date or even the make of the steering box. It might be original. (See pics). The engine is as far up as it will go. I need like 1/2 “ clearance to make it work. Has anyone relocated a steering box off center by a fraction to clear steering ?? Does it work ok?
    Any advise would be great. [​IMG][​IMG]
    biggeorge likes this.
  2. flat 39
    flat 39
    Are you using Mercury or Ford truck water pumps? They are different.
    The steering box mount looks to be a home made piece and is probably not in the original location.
  3. flatjack
    flatjack
    Definetly not the correct mount.
  4. Project 29 Tudor in mass made a bracket to put the box on top of the frame.
  5. Ralph Moore
    Ralph Moore
    Not the stock steering box, a 36 box would have the “egg” at the bottom for the Horn/ light switch wiring harness to attach to. May be a later 40-48 box installed to improve steering like on my 35.
  6. 36 Penny Coupe
    36 Penny Coupe
    from VA
    Thanks for the info guys. We just moved the box over into the frame rail 1/2 and it worked out. I think it’s a Ford truck box. Looks really heavy built.
