Fenton 235 Header gaskets
Discussion in 'The Hokey Ass Message Board' started by Westside Lefty, Dec 11, 2008.
  1. Westside Lefty
    Westside Lefty
    from Venice
    Can't seem to find 'em. Help a brother out.
  2. Little Wing
    Little Wing
    from Northeast
    Um why not just use stock gaskets?? is there some difference
  3. Westside Lefty
    Westside Lefty
    from Venice
    Not sure. Does anyone know?
  4. i used the stock ones for about 5 years now....no problems
  5. fordcragar
    fordcragar
    from Yakima WA.
    That's all I ever used, was the stock gaskets.
  6. Ball and Chain
    Ball and Chain
    from Nor Cal
    i had leak problems, i ended up buying a composite gasket and stud problem solver kit from a place online. there tag said "a must have for fenton headers" i wish i new the name because, i need a set for another engine.
  7. Westside Lefty
    Westside Lefty
    from Venice
  8. if they exist tom langdon's would know. check out his site.
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    when i had em on my 235 i just used the stock gaskets..worked fine
  10. saltflatmatt
    saltflatmatt
    Alliance Vendor
    Yep- Stock gaskets work fine...
  11. Little Wing
    Little Wing
    from Northeast
    woo hoo ,,I got one right :)
  12. Snarl
    Snarl
    Stock is all I ever use, and should always work when using an iron manifold, unless the manifold is really warped, in which case you need to have it machined regardless of the gasket type.
    I believe Larrowwe & Sons may sell a one piece gasket?? check them out...
  13. oilslinger53
    oilslinger53
    from covina CA
    use, or cut some stock ones.
  14. Road Runner
    Road Runner
    The newest white one-piece 'problem-solver' gaskets are no good any more.
    - They crack around the exhaust ports after just a few miles.
    The older grey ones are holding up well without leaks for years on my daily 235 ... if you still can get them.
    Just use the stock ones and check or machine intake and exhaust manifolds for level surface.
  15. Ball and Chain
    Ball and Chain
    from Nor Cal
    what company makes that white gasket? i had good luck with them and would like another, for a different motor.
  16. PeteFromTexas
    PeteFromTexas
    Stock is fine. NO problems here
  17. gup
    gup
    from Washington
    A company called remflex sells them, they are not cheap (around $60.00) but they work awesome. Extra thick graphite with a steel core. Check your local parts store and see if they are a dealer for them or just buy them off of their web site.
  18. The_Monster
    The_Monster
    I tried a stock 3 piece gasket. I had intake leaks BAD. I found a company called remflex.
    Check these links out.
    Heres the link to buy the gasket:
    http://catalog.remflex.com/CHEVROLET_GM_CHEVY_Header_Exhaust_Manifold_Gasket_p/rf2027.htm
    Heres a link to read about the gasket and why itll be the last one you buy:
    http://catalog.remflex.com/category_s/154.htm
    Yea, theyre a bit pricey, but the stock 3 piece wasnt an option for me. Anyways, I love them and I have NO leaks, and never will down the road from blow out! :)
