Features Fenderless Model A's, Show Us Your A-Frames!
Discussion in 'Traditional Hot Rods' started by Weezy1930, Nov 26, 2014.
  1. P3010003.JPG Roadster on A frame
  2. 1. How did you lower the rear end?
    I used a Model A rear spring, with the main leaf reversed and three top leafs shortened and added under the pack. I think it has 7 leafs total including the 3 shortened leafs. I used Model A perches on a later banjo to keep it a spring over setup. The chassis has been Z'd the thickness of the chassis so maybe 2.5" or so? Pretty much how the Tardel book describes it.
    2. How did you tilt the windshield?
    The windscreen posts / frame is chopped 4", and then i pie cut and leaned the posts back until i was happy with it. They were cut right above the top mounting bolt, almost in line with the dash rail if i remember correctly.
    3. it is -17 degrees c here right now!!
    It's around 30 degrees celcius here at the moment.. i'd much prefer our winter temps of around 17 - 20 degrees. Its too damn hot. Had 42 degrees a week or so back.. feels like a damn oven.
    indomwe likes this.
  3. Southfork
    Southfork
    That's one cool little roadster 28A!
    28A likes this.
  4. JJonesey
    JJonesey
    My work in progress. Kinda sorta HAMB-friendly.
    luckylou, brEad and keywestjack like this.
  5. louisb
    louisb
    I like it. What are the specs on the chassis. Looks like you went with a slight channel.
    --louis
  6. JJonesey
    JJonesey
    Thanks. 2x4 rails I formed to the stock contour up front. Stretched 4" and the dropped crossmember was moved forward another 1". All other crossmembers were done with roll bar tubing. The body is wedge channeled about an inch up front.
    One of these days I can post some build pics if there's any interest.
    louisb and AHotRod like this.
  7. JJonesey
    JJonesey
    In progress...
  8. F-6Garagerat
    F-6Garagerat
    Couple pics of my 30 AV8 Pickup on an A frame. Last pic is when I broke it a few weeks back, I was equally thrilled about that and the impending doom of winter. Couldn't even get that last ride out to the shop, had to tow it.
    13clicks, brEad, barrnone50 and 9 others like this.
  9. mike bowling
    mike bowling
    Figured I'd throw these into the mix too-Always use "A" frames! You bet your "A"(ss). First is stock for my blue Banger roadster, second is frame under the green and black coupe I posted a picture of earlier.Rear has a 4" step and triangulated 4 bar set up ,4" drop axle and reversed eye spring(later) at the front.(It is stock, I just moved stuff around a little!) All "A", all the time. FORD MOTORS ONLY!!
    CTAV8 likes this.
  10. F-6, that's a cool rig ! JW
  12. F-6Garagerat
    F-6Garagerat
    Thanks man.
  13. F-6Garagerat
    F-6Garagerat
  14. louisb
    louisb
  15. banginona40
    banginona40
  16. BLACKPRIMERFAN
    BLACKPRIMERFAN
    from OH/MI LINE
    Bangin, Damn that sits right! What color is the coupe?
    LTM75110 likes this.
  17. banginona40
    banginona40
    Thanks, and glad you like the color. It was a special mix to be a close match to DP 40. I have sent the formula to a half dozen HAMBERS who have requested it.
  18. dan31
    dan31
    Banginona40, that car looks great. Do you have any other pics of the rear roll pan?
  19. AHotRod
    AHotRod
    Wow!
    Spot-On!
    Let's see more!
    Glenn
    volvobrynk and LTM75110 like this.
  20. Harvey29
    Harvey29
    from kansas
    volvobrynk likes this.
  21. VintageSpeedGarage
    VintageSpeedGarage
    Our 1929 Ford Coupe, finished about a year ago.
  22. joeyesmen
    joeyesmen
    Here's mine . . .
  23. Autodave
    Autodave
    from Menifee,Ca
    Excellent!! Any more pics?
  24. scrap metal 48
    scrap metal 48
    Hey 'joeyesman', that's a very cool coupe.. Nice job....
  25. jkeesey
    jkeesey
    Mines not as shiny as everyone elses but still on an A frame with the original banger. Remaking the body this winter once I finally stop driving it.[​IMG]
    keywestjack, CTAV8 and volvobrynk like this.
  26. Bull
    Bull
    My A's . . . all on A frames:
    Two fenderless.
    One with fenders.
  27. racer32
    racer32
  28. harleyjohn45
    harleyjohn45
    41 Ford front with a split bones suicide front end. Not finished yet, but getting close. Ruidoso Decemberr 2014 car pictures 006.JPG Ruidoso Decemberr 2014 car pictures 007.JPG
    keywestjack, hipster and volvobrynk like this.
  29. Mightyaxeman
    Mightyaxeman
    I picked this up this past summer. ImageUploadedByH.A.M.B.1418506573.735099.jpg
    brEad likes this.
  30. GASSERBOB
    GASSERBOB
    from USA
    Here's some photos of my 28 that I'm still working on.
      1 MB
      1 MB
      1.1 MB
      1.1 MB
      1.1 MB
      1 MB
      1.1 MB
      1.1 MB
