Technical Fender or Body Bolts; where to get 'em ?
Discussion in 'The Hokey Ass Message Board' started by gatz, Aug 2, 2019.
  1. gatz
    gatz
    Looking for some 1/4-20 fender or body bolts like this (but doesn't need the dog-point) ; not sure of the correct nomenclature. This particular one is 3/4" long and has a Ø3/4 washer which would be fine.
    I've been on a few websites that sell them, and the best price for 1/4-20 x 3/4 was 40¢.
    They go on up to 80¢ each.
    Also will be looking for 5/16-18 x 3/4 and 3/8-16 x 1"
    thanks for any help.
    gatz
  2. evintho
    evintho
    Junkyard.
    rust runner and Oldioron like this.
  3. 1ton
    1ton
    I'd wager that most people on the HAMB have at least one coffee can full. I know I do. Problem is finding them.
    kidcampbell71 likes this.
  4. Chavezk21
    Chavezk21
    Fastenal has been my go to.
  5. shivasdad
    shivasdad
    from Texas
    Boltdepot.com has full thread flange bolts, but they don't have the pilot point. They also carry fender washers in a good variety of sizes.
    Flathead Dave likes this.
  6. gatz
    gatz
    Fastenal carries them ?
  7. Flathead Dave likes this.
  8. gatz
    gatz
    McMaster-Carr has expensive stainless steel ones.
    Didn't see any "common" phosphate steel ones; unless I wasn't looking in the right place.
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
  10. s55mercury66
    s55mercury66
    from SW Wyoming
    Those particular bolts can be found holding the grille shell onto 1973-79 Ford pickups. 8 of them to a truck, 6 of which are right on top, and 2 attach the shell to the fenders right behind the bumper.
    Texas Webb likes this.
  11. s55mercury66
    s55mercury66
    from SW Wyoming
    There are also.some shorter 1/2" long ones holding the door and window parts on, on the same vehicle.
  12. 36cab
    36cab
    If you search the big auto part store websites they will have them. I use the term body bolt. The free spinning attached washers are sometimes called SEMS washers in the description. I also use the term dog pint in the search. Both Dorman and Auveco seem t be the manufactures of these bolts that the big parts stores carry.
  13. brake1000
    brake1000
    from ID
    AMK Products might have what your looking for
  14. 1ton
    1ton
    Anyplace that sells auto paint and supplies is going to have all the body bolts, washers, captured nuts and shims you need. At least the ones around here do. And there's always Amazon.
  15. ekimneirbo
    ekimneirbo
    I agree with the guys that reccommend going to a junkyard. Be sure to take a battery powered drill,a set of sockets, a socket drive adapter and a ratchet or wrench for the tough ones. Should be able to get a bunch of them for your home shelf "stock". A ratcheting wrench would be nice too !
  16. Try ace hardware. HRP
