Fender lengths needed: '36 and '39 Ford
Discussion in 'The Hokey Ass Message Board' started by Hans' Rod & Cycle, Dec 23, 2013.
  1. I would be very grateful if someone could measure the length front edge to rear at running board mount of these two front fenders. Can be standard or DeLuxe, they are probably fairly close. Thanks a ton, Hans
  2. Jalopy Joker
    Jalopy Joker
  3. I can't be the only one in the garage on Christmas Eve...;)
  4. TagMan
    TagMan
    I'd be glad to measure my '36 fenders, but I won't be home until this Saturday. If you don't get a reply by then, PM me and I'll get the length for you.
  5. 39 Ford
    39 Ford
    I do not have both but as the frames are interchangeable, suspect they are within an 1" or so of each other.
  6. Yeah, I bet they aren't too far off, the shape of the 36 makes it look alot smaller. I'm in the planning stages of a custom build and wanted to compare lengths with some other bigger cars as well.
    Any measurements very much appreciated.
  7. From the front of the fender in line with the centre "ridge" to the vertical edge that bolts up to the running board, 1480millimteres.
    I just measured it on a fender I was painting,
  8. Thanks! So that's from the bottom/front edge measured underneath to the rear where the running board mounts right?
  9. Yep, in straight line. It would be through the middle of your wheel if it was fitted.
