Fan Spacer question
Discussion in 'The Hokey Ass Message Board' started by STREETREBEL, Apr 24, 2013.
  1. STREETREBEL
    STREETREBEL
    I need to get my fan ( engine mounted ) closer to
    my radiator.
    Can I use a 5 1/2 inch spacer without it breaking?
  2. Molonewolf
    Molonewolf
    I wouldn't try it.
  3. Streight8
    Streight8
    If you can't find a factory installed one of that length then is likely too long. Is there an option to put in a longer "nosed" water pump then a shorter spacer. Maybe split the difference, maybe give engine type and size and some one may have a suggestion.
  4. why can't you make a shroud?
  5. Bert Kollar
    Bert Kollar
    X2 on the shroud. My big block Mopar is way back from the radiator so I made a shroud and it never runs too hot
  6. I once drove an O/T corvette with a 4-5 inch fan spacer installed by previous owner. At about 6500 RPMs. it snapped the water pump shaft and sent my fan into the radiator..$pensive lesson.
  7. black 62
    black 62
    from arkansas
  8. tommy
    tommy
    Use both a spacer and a shroud. Check out the shroud on a 60-70s Monte Carlo.
  9. why is the radiator so far from the fan that you need a 5" spacer?
  10. onedge
    onedge
    Same question why the need for? Tommy that shroud looks like half of a 55gal drum 70 monte I have to look into that never saw one.
  11. terryble
    terryble
    from canada
    Monte Carlo's and early 60s buicks had very long fan spacers in that 5 inch range and seemed to work, still would make me nervous though.
  12. junk yard kid
    junk yard kid
    i once tried two spacers. (i was young) yep snapped the water pump shaft and destroyed my radiator.
