I'm fabbing up a fan shroud for my roadster. I've been debating amongst myself whether my fan is in to deep . I really don't want to trim ,but I am thinking of maybe trimming a 1/4" to 1/2" off of the depth? I thought I would run it past you guys , Thanks , Bill
That will probably work. in a perfect world a little shorter would be better but I am pretty sure that it will work the way that it is.
Why thank you, I appreciate that. I wanted something inconspicuous , so I made it to snuggle in between the rad and the grille shell. .I'm planning to paint it and the radiator black , I think it shouldn't catch your eye. Thanks , Bill
Originally I intended to make a hammer form and try to create a one off shroud, but my aching wrist and elbows thought otherwise. So I made something more functional that is clean and does it's job. I ended up trimming 3/8" from the depth and then proceeded to weld everything up. This is the end result. I just have to figure out what color to paint it . Black , body color or engine color, I 'll figure that out at a later date. Bill
What size fan is that? Whole package looks well thought out / engineered. I have the same water pump riser and am curious how big a fan you stuffed in there
15" https://www.summitracing.com/search...tBy=Default&SortOrder=Ascending&keyword=17415 Thanks, I appreciate it, Bill
