Projects Family Affair...resurrecting an AD Chevy
Discussion in 'The Hokey Ass Message Board' started by Count Scrapula, Sep 23, 2013.
  1. Count Scrapula
    Count Scrapula
    from Mid TN
    I sleeved the bolt hole so as not to crush the tubing when the cab was bolted down.
  2. Count Scrapula
    Count Scrapula
    from Mid TN
    Swinging the cab back in place
    Me bolting back cab mounts
  3. Count Scrapula
    Count Scrapula
    from Mid TN
    I don't have a pic, but the entire underside of the cab was coated with POR 15.
  4. BBYBMR
    BBYBMR
    You guys are doing a nice job! Great to see several generations working together.
  5. Count Scrapula
    Count Scrapula
    from Mid TN
    My son goofing off after setting the cab
    Bolting on some rollers
  6. Count Scrapula
    Count Scrapula
    from Mid TN
    Garage night
    We decided to hang the doors back on so it would start looking more like a truck
  7. J'st Wandering
    J'st Wandering
    I went back and read it all again. What a great build. Thank you for sharing.
    Neal
  8. Count Scrapula
    Count Scrapula
    from Mid TN
    In this pic you can see kick panels and inner cowl installed, but lots of work left on the outer cowl and firewall
    The rear is out of a '69 Mercury Montego, narrower than most people use on these trucks
  9. Looks great so far! Lots of hours fixing rust.
  10. Tin Can
    Tin Can
  11. Count Scrapula
    Count Scrapula
    from Mid TN
    Differential was in good shape, but we replaced bearings, seals, brakes, etc.
    Here's Dad bolting the rear end in for the first time. ImageUploadedByH.A.M.B.1382464744.956216.jpg
    Springs are from Chassis Engineering
  12. Count Scrapula
    Count Scrapula
    from Mid TN
    Gas tank installed
    While Dad was bolting in the rear my friend Tim put a skim coat on the cab corners.
  13. Count Scrapula
    Count Scrapula
    from Mid TN
    I found this interesting repair on the tear down. Not one, but two safety pins.
  14. Haha - well, you can never be too safe you know!
  15. shadams
    shadams
    What's the big deal? It's just the gas pedal....;)
  16. Count Scrapula
    Count Scrapula
    from Mid TN
  17. Count Scrapula
    Count Scrapula
    from Mid TN
    Sorry I've not updated in a while. For some reason the app wouldn't let me upload pics. I reinstalled and seems to be working.
  18. Count Scrapula
    Count Scrapula
    from Mid TN
    Here I am welding up all the extra holes in the firewall. There were 50 of 'em.
  19. Count Scrapula
    Count Scrapula
    from Mid TN
    Priming cab corners
  20. Count Scrapula
    Count Scrapula
    from Mid TN
    Firewall primed
  21. shadams
    shadams
    Nice....I feel sick everytime I look at pics of others doing the rust repairs. I am so glad I am past that part.
    Are you going to try and match the paint on the corners to the og paint? I found a Rustoleum hunter green that is almost a dead ringer for the og green, so on mine I am going to use it to spray the spots I repaired and then wet sand it to try and match. I eventually want to do a rear paint job but that should get me by while hiding some of the work I did. Should be too hard to find a black that matches...
  22. SanDiegoJoe
    SanDiegoJoe
    Such a great project.
  23. Count Scrapula
    Count Scrapula
    from Mid TN
    Yes, blended the paint. Base coat black with no clear matches the sheen well. I WILL NOT paint this truck. I want it to look like it did when I was a kid.
  24. Count Scrapula
    Count Scrapula
    from Mid TN
    Test fit of engine and fabrication of motor mounts
  25. Count Scrapula
    Count Scrapula
    from Mid TN
    Another angle
    Here's how I made the motor mounts
  26. Count Scrapula
    Count Scrapula
    from Mid TN
    The seat is out of a late 80's Chevy pickup recovered in oxblood red cause that's the color it was when I was a kid. I remember my Mom making the seat cover and matching steering wheel cover for it in the 70's.
  27. Count Scrapula
    Count Scrapula
    from Mid TN
    Here's a pic of Dad behind the wheel as we're getting ready to load it up to take it to get exhaust.
  28. Great thread! I'm building a 54' myself. Love lookin at other peoples work
  29. Count Scrapula
    Count Scrapula
    from Mid TN
    Here's where I cut the original brake pedal mount.
  30. Count Scrapula
    Count Scrapula
    from Mid TN
    After cutting the brake pedal mount I made a template out of 1/4" plywood for the new master cylinder.
    After welding the new master cylinder mount in, this is the way looks in the frame.
