Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. mgtstumpy
    mgtstumpy
  2. scrap metal 48
    scrap metal 48
    Really cool^^^.....
    Deuces, Gammz and lothiandon1940 like this.
  3. Boulderdash
    Boulderdash
    New years thread bump, and a question.
    I have a 63 Falcon with a '66 Mustang 8" axle, albeit currently out of the car and in pieces (flange to flange is 50 13/16"). The existing steel wheels have 4" backspacing and 195/75 R14 tyres. I am tempted by some Cragar SS 14 x 6 rims, but they have a backspacing of 3 3/8" and 175/65 R14 tyres, and I fear they will scrub on the outer wheelarch lip. Any ideas if they'll fit?
    Obviously the shallower backspacing will put them further out, but then the narrower tyres (approx 3/8" either side) should help redress the balance somewhat. Would rather not cut the inner arch lip off, if I can help it.
  4. 62rebel
    62rebel
    Was the axle in the car when you got it, or was it something you found separately? Roundbody Falcons are notorious for being difficult to install a v8 capable rear axle into. You are probably going to have to modify (narrow and move spring pads) the Mustang axle to get it to fit at all. Nothing that is horribly involved, but labor and time nonetheless.
  5. Boulderdash
    Boulderdash
    It came with the '66 axle already fitted, so I already know it will fit with the 14" 4" backspace steelies.
    62rebel likes this.
  6. 62rebel
    62rebel
    That's a stroke of good luck right there.
  7. mcnally351
    mcnally351
    from boston
    Does any falcon guys know if the door hinges on a round body is the same through the years? They look similar on the 64. Even mustang hinges look the same and are available through macs. I’m looking for a drivers side 61 upper. Thanks!!
  8. 62rebel
    62rebel
    You need someone who has a hollander interchange manual to really answer your question. I imagine that they are very similar but I couldn't guarantee it.
    mcnally351 likes this.
  9. Nailhead A-V8
    Nailhead A-V8
    can't just replace the pins and bushings?
  10. Nailhead A-V8
    Nailhead A-V8
    8" - '72-'77 Maverick/Comet bolt in with '66 Mustang spring plates, Mav/Com 4dr. driveshaft also bolt in
    9" - 1957 Ford
  11. 62rebel
    62rebel
    Not picking but those donors are more rare than the Falcon now
    Nailhead A-V8 and Gammz like this.
  12. What kind of HP are you throwing at an 8” rear end.
  13. Don’t think I ever put mine on here...wanted a hot little street car...289, 11:1, TW Heads1, Eddy Performer RPM intake, custom ground comp cam.. built C4, 2500 Stall converter.....and a Maverick 8”
    Front ends all Opentracker from the master out.. DC49B1A2-34DF-401B-981C-F8274A54AF8C.jpeg E3A54466-9C42-447E-96B2-752B752FF044.jpeg 8AA65B8E-5BDE-43C1-8710-79F02BB1981E.jpeg 516CB324-8674-4181-84F7-1E49474E368A.jpeg
  14. mcnally351
    mcnally351
    from boston
    That’s a good idea thanks
  15. mcnally351
    mcnally351
    from boston
    I was backing up the car with the door open and wrecked the door on my wood pile and broke the hinge. I have since welded the hinge back together and found a door but hoping to find another hinge
  16. RmK57
    RmK57
  17. 62rebel
    62rebel
    post up a pic, I might have a loose one I can give you
  18. Don’t know yet...been trying to get it wrapped up..between work and now COVID haven’t done anything to it..last thing that got done was getting the headers on it and plugs in..no easy feat..had to make some tools....gotta get a new fan, a spacer, and a trans cooler, bend all the lines for fuel and trans cooler, mount and hook up gauges, get shifter hooked up, and get u joints on and drive shaft installed..then gotta break it in...Gave Comp my parts list and my desire to have power from 1800-6000 rpm, told them I’d run premium fuel, and they did the cam..really compression is about 10.8:1..but close enough..should be a Snappy little motor..
    Basically I used some some of the info below..and Alex knew his stuff..I opted for better heads..and aluminum will allow a little more CR..also have a 3 core aluminum radiator and hi flow aluminum water pump..I’m hopeful for 350 hp...should be a real fun little car..
    http://mustangsandmore.com/ubb/BudgetSmallBlock.html
    MUNCIE likes this.
  19. Saw this on FB Marketplace..nicely done little street car 068CAA51-B0A4-4ACE-97B6-59C40C5E5D7A.jpeg 8119FCC6-8CE5-4341-B88A-77E2EC040B30.jpeg
  20. Nailhead A-V8
    Nailhead A-V8
    Yeah that little mod of using the stock wheel arch from a pair of front fenders for the rear wheel arch is the only way to get any rubber under a Falcon... and so subtle compared to a custom (bondo) flare
  21. gimpyshotrods
    gimpyshotrods
    1990-1992 Ford Ranger 8.8. 1/2" wider than stock.
    Or, Explorer 8.8, narrowed to use two short-side axles.
    Both were made by the hundreds of thousands, and are currently in yards.
    Gammz, 62rebel and Nailhead A-V8 like this.
  22. Nailhead A-V8
    Nailhead A-V8
    what's the bolt pattern? seems to me it's the old chevy pattern? or is it the same as 60's
    ford 5 lug?
  23. gimpyshotrods
    gimpyshotrods
    Both the Ranger and Explorer are 5-on-4-1/2", same as Ford passenger car, of the US Falcon era.
    Nailhead A-V8, Gammz and 62rebel like this.
  24. Boulderdash
    Boulderdash
  25. gimpyshotrods
    gimpyshotrods
    I used Falcon front arches. I tightened the radius a bit, and mounted them lower back than the fronts.
    MUNCIE, brEad and 62rebel like this.
  26. 62rebel
    62rebel
    I have two sets of those I've been holding onto for years. Need me another round body tudor
    gimpyshotrods likes this.
  27. Anybody got a T Bolt hood they wanna part with for a 64-65 Falcon?
  28. gimpyshotrods
    gimpyshotrods
    They are starting to creep up in price. Folks used up all of the Mustangs.
  29. Boulderdash
    Boulderdash
    Very nice. So this allows larger rear wheels?
    Digging the fuel filler cap mod too
  30. gimpyshotrods
    gimpyshotrods
    The fuel filler is from an XJ Jag. The cap is not featured in the picture, as that primer was wet there.
    This is one step to larger wheels.
    The wheel houses in Falcons part company with the quarter panel at the wheel arch. From there, they move inward quite quickly.
    That tends to interfere with a wider tire, especially so if lowered.
    I added these.
    62rebel and RmK57 like this.
