F150 Headlight
Discussion in 'The Antiquated' started by Bri62, Jun 19, 2020.
  1. Bri62
    Bri62
    from Ontario
    kjbnhbmnmj
  2. The Magic Ratchet
    The Magic Ratchet
    When unusual things like this happen, it generally relates to a bad ground somewhere. The two main grounds on your truck are battery to body and body to engine. Make sure they are in place and working. I think the rest of the ground system is through the body so any rusted sheet metal could cause a problem. The usual suspect for "no headlights" is the dimmer switch but your's seems okay. You may also want to have another go at the firewall connector.
    Lou
