F100 Pitmam arm - interchange??
Discussion in 'The Hokey Ass Message Board' started by 48bill, Oct 4, 2009.
  1. 48bill
    48bill
    I am using a 1953 -56 F100 steering box in my modified roadster. The pitman arm is a completely different style of attachment and spline than the F-1 and the 1932-48 ford car.
    Are there other pitman arms that will interchange with the F100 style that will get away from the ball style mounting of drag link where I can use either a tyrod end or a heim joint on the F100 box?
    Thanks for the help.
  2. heavytlc
    heavytlc
    Grind off the backside of the pressed ball, remove the ball and weld, or drill to the size you want. I run a dodge d100 steering box in my 56f100, had to weld the f100 steering ball in the d100 steering arm. What I did was what you need in reverse.
  3. hugh m
    hugh m
    from ct.
    I used an F 100 pitman arm on my 37 ford stock car just by filing a few splines in it...don't know if it would work like that the other way around, but would certainly be worth a looksee.
  4. landseaandair
    landseaandair
    from phoenix
    I think a later F100, 57 and up arm is a bolt on and uses a standard tie rod end.
  5. cuznbrucie
    cuznbrucie
    This is correct.......you need to get a 1957 F-100 pitman arm.......I am using a box from a '56, but with a '57 pit arm........works like a charm.....
    I got mine brand new from John's F-Fun Hundreds:
    http://www.johnsf100.com/
    CB
