f100 front axle differences
Discussion in 'The Hokey Ass Message Board' started by Shotdowninflames, Jun 19, 2011.
  1. Shotdowninflames
    Shotdowninflames
    from Milwaukee
    Does anyone know if the front axle off a 1964 f100 (2wd) will work on a 1960 f100 (2wd)?
  2. jamesdfo
    jamesdfo
    Maybe?:):) Take a look @ dimensions on Sid's site, they have physical differences, but dimensions listed appear similar......might be worth dropping a dime to ask, or better yet, just order up a dropped one!!:)
    http://www.droppedaxles.com/FORD_AXLES.html
    HTH
    James
  3. Shotdowninflames
    Shotdowninflames
    from Milwaukee
    Thanks Jamesdfo. I had that same thought. The reason I am asking is because I found a Sid's front axle out of a '64. I was planning on having them drop the one in my '60. The specs. on their website are listed as the same. There is a notation about shock mounting holes on the '64, but nothing on the '60. If the '64 axle would work, I could save a lot of time and money. Any info. would be appreciated. I hate to bother them at Sid's if I don't have too.
  4. 55 Mercury
    55 Mercury
    The 64 axle will bolt right in your 1960. The only thing really different is the appearance. The measurements are the same KP to KP, SP to SP and take the same kingpin set and spindles
    www.droppedaxle.com
  5. willymakeit
    willymakeit
    I think they are the same 57 up. I use the later axles on the 53-56 to gain an extra 1 1/2'' in drop.
  6. Shotdowninflames
    Shotdowninflames
    from Milwaukee
    Thanks guys. Springs and axle bolted right in.
  7. mrt777_91910
    mrt777_91910
    CCP has a droped front axle for the 57 and up F100 so if you not sure give them a call and order it from them brand new.
