f-1 parts what years
Discussion in 'The Hokey Ass Message Board' started by box50, Jan 31, 2013.
  1. box50
    box50
    Which year f-1 trucks are the one's that have the brakes steering box that I will need to use for my 31 model-A, what years will work Thank's.
  2. 41hemi
    41hemi
    Any F1 from 48-52 will have what you need!
  3. box50
    box50
    What about using a vega steering box, anyone done that.
  4. You can buy vega and corvair boxes new believe it or not.
    Some of the fellas were using early Mustang boxes a few years back, they can be mounted almost under the toe board and out of the way of everything.
    But F-1 or F100 is the way to go. The F-100 boxes are bigger but that is what we used to use all the time.
  5. Beau
    Beau
    Ford F1 was only made 48-52.
    The Tardell Book has your info.
  6. Fenders
    Fenders
    For brakes look at 53 - 56 F-100
  7. bobj49f2
    bobj49f2
    BTW, F-1, F-2 and F-3 had the same box so you have wider selection to look for.
    Also, a lot of the Ford truck guys use a Toyota truck box to replace their original boxes, something to consider.
  8. box50
    box50
    Cool guy's thanks for the info,I did not know about the pedal assembly and crossmember good to know I know where there is a ford truck around that model need to check it out.
  9. box50
    box50
    I am running a t-5 on the flathead,any ideas on that my buddy says I will need to run some f-1 pedals.
  10. 48-52 F-1 is the best swap. 53-56 F-100 and 57-60 F-100 also work. 53-56 and 57-60 are same box. The pitman arm is the difference, 53-56 has the ball stud, and 57-60 has the tapered tie rod end, for the drag link. Both 53-56 and 57-60 have the large pinch bolt. The F-1 uses the same spline as early Ford car with large nut to hold pitman arm on the shaft. F-1 has the ball stud.
    Pay your money and make your choice.
