Technical exhaust questions
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Sep 15, 2020.
  1. Ron Brown
    Ron Brown
    Im ready to build an exhaust system for my roadster....will be using block hugger headers and have a question about what size pipe to use....mild built 4 bolt main 350, mild roller cam, roller rockers and th350 trans......the headers come with 2.5" to 2" flanged adapter for 2" tubing but was wondering if I should go to 2.25" or 2.50 inch tubing from collector back....I am removing the lakester style exhaust to run a milder sounding mufflered system....
  2. squirrel
    Either will work. The smaller it is, the easier it will be to fit. It doesn't sound like you really need the couple extra HP the larger system might give you.
    Elcohaulic and olscrounger like this.
  3. Ron Brown
    Ron Brown
    so your saying go with the 2" system?
  4. squirrel
    I was thinking 2 1/4, which seems to be what you had in mind. 2" would work too...you'd lose a bit more performance, though.
  5. Ron Brown
    Ron Brown
    cool...thanks for the input Jim......hope all is well with you and yours.
    squirrel likes this.
  6. Blues4U
    Blues4U
    from So Cal
    I'd go 2 1/2 from headers to mufflers, and 2 1/4 from mufflers to the rear bumper.
    Elcohaulic and Truckdoctor Andy like this.
  7. Mr48chev
    I've got to go with Jim on this one. 2 inch might fit under the car a whole lot better than 2-1/4 although i have run 2-1/4 on most of my OT V8 powered rigs. The guy who did the exhaust on my 51 Merc with the 350R Olds in it cussed a blue streak when he was fighting with the 2-1/4 pipe under it but it sure sounded nice but I had a 455 that I was building for it and the larger pipe was intended to be used with the 455.
  8. jimmy six
    jimmy six
    If you’ve been fighting noise and looking for a quiet as you can do successfully I would go 2”, the longest or fattest muffler you can even adding augers in front of them and tail pipes out the back. You can chrome tip them like traditional or turn down and flat cut to hide them. I like both. For really quiet go to one of the aftermarket cast iron exhaust manifolds like Sanderson. Good luck
    olscrounger likes this.
  9. squirrel
  10. Ron Brown
    Ron Brown
    thanks guys....im not necessarily looking for "quiet", just quieter than these lakester exhaust Im using now 6238ACD7-ACD7-493A-9C41-994D0EFB30EE.jpeg
  11. Dino 64
    Dino 64
    from Virginia
    Same engine except the cam, went with 2 1/4.
    My 2cts. Good luck with it
    Just Gary likes this.
  12. Ron Brown
    Ron Brown
    Im leaning this way thanks
  13. Ron Brown
    Ron Brown
    thx....I will be using mandrel bends and building myself....so if anyone gets frustrated, it'll be me....lol
  14. wackdaddy
    wackdaddy
    I am running similar power and ran 2" through a pair of Brockman mellow tones. Super happy with tone and noise level. 2" will be easier to snake through the frame if you are looking to keep it tucked up high
  15. gene-koning
    gene-koning
    The difference in performance between a 2" pipe and a 2 1/2" pipe won't become noticeable until you get into the upper rpm range, and then the differences won't amount to much. The higher RPM range that would effect the performance rarely happens on a street driven vehicle. Gene
    tb33anda3rd likes this.
  16. 41rodderz
    41rodderz
    from Oregon
    So how have you and yours and the house fare from the fire ? Update if you will .
  17. Ron Brown
    Ron Brown
    were all safe, but not allowed access to our place yet....may be middle of Oct. till allowed back...as far as we know our home is still standing but only about 20% containment of fire yet....hopefully all will be fine....thanks to all for the concern.
    Just Gary, 41rodderz and Blues4U like this.
  18. Ron Brown
    Ron Brown
    very nice
  19. Ron Brown
    Ron Brown
    who built your chassis....looks identical to mine
  20. I was going to ask how you were doing; glad to hear you're okay, and your property still seems good too.
  21. wackdaddy
    wackdaddy
    Gary at Blackboard Hotrods in Bakersfield
    Ron Brown likes this.
  22. Blues4U
    Blues4U
    from So Cal
    I'm curious Ron, are your lakes headers baffled?
  23. Ron Brown
    Ron Brown
    yes and wrapped in glass...its acceptable but gets pretty loud on acceleration...in fact, ive been in a habit of coasting past any cops I come across just in case
  24. Ron Brown
    Ron Brown
    That explains it, so is mine, very nice work
    wackdaddy likes this.
  25. mgtstumpy
    mgtstumpy
    2 1/4" from block huggers back to mufflers (Under rear seat) where it steps up to 2 1/2". Tail pipes are 2 1/2", decent sound and average performance for a stock 5lt SBC.
