Hot Rods Ever see a piston spin sideways in a cylinder bore?
Discussion in 'The Hokey Ass Message Board' started by Chaz, Jan 27, 2011.
  1. At 201 MPH on the salt this big block chevy let go... The piston spun sideways in the bore tearing off the skirts, and splitting the piston in half. It's almost a perfect sphere. The rod was bent all to hell and the wrist pin bore oblonged. That's the top of the piston facing left.
    I've seen lots of gernaded engines, but this was a new one for me.
  2. temper_mental
    temper_mental
    from Texas
    What type of piston?
  3. henryj429
    henryj429
    Yup, been there, seen that....on a single cylinder ATV engine in my case
  4. Zombie Duck
    Zombie Duck
    Nope never seen one do that before, I hope they hang it up above a fireplace or something, talk about a conversation piece.
  5. seen a piston in a semi diesel do that...
  6. Toymont
    Toymont
    from Montana
    Not sure what brand piston but it was a big block chevy engine the rod was stock
  7. We were drag racing down in Phoenix one time, the driver reported the engine rattled after he crossed the finish line. He thought it broke a piston. We did a leak down test to find the bad hole. Pulled the head, the piston was sideways, I screwed a sheetmetal screw in the top of it and pulled it up out of the hole with a pair of vice grips. Broke the rod into just below the wrist pin.
  8. BOBCRMAN
    BOBCRMAN
    from Holly
    Looks like an old TRW/Speedpro type piston from whats left.
    I had a customer bring in a 460 Ford for rebuild. The piston was like that. Plus the rod was folded over double and wadded up alongside the piston.
    "Shut er off when I heard the noise!"
  9. 42 chevy
    42 chevy
    That is creepy looking. I would kind of like to see the cylinder it came out of or what is left of it. At 201 MPH that could have been scary. I blew up my first engine at 115 MPH and it threw a rod locking up the whole rear end. I was 16 and boy was that a ride.
  10. Deuces
    Deuces
    from Michigan
    Here's one for ya's!!!.... How about a train that let one loose, goes flying through the air and inbed's it's self into a wall at someone's house??? No kidding! check out the pictures! :D
  11. Rock Island Rocket
    Rock Island Rocket
    Wow i have never seen that unless the rod was broken! How much piston to cylinder clearance did you have?
  12. michaelmoore
    michaelmoore
    now thats some kinda cool
  13. 32-3 WINDOW
    32-3 WINDOW
    from utah
    mama always said stay away from trains , planes and other guys wives , i wouldnt want any of them coming thru my wall , thats wild
  14. Holy Shit!
  15. Deuces
    Deuces
    from Michigan
    Yeah!! Glad nobody got hurt from that one... The train company paid in full for all the repair work...
  16. A Chopped Coupe
    A Chopped Coupe
    Knock on wood I've never scattered a motor before.
    A friend has a 71 Camaro with BBC drag car and two stage 250 shot of NO2. While running for his NHRA license (it's a 9.50 car) he lost the motor on the top end and still coasted to a 10.20..............when he tore the motor down number 4 piston had now found a home on top of number 6 piston. Surprisingly nothing came outside of the block, but the inside was mess.
  17. 52pig
    52pig
    Beautiful...so did you throw another one in and run?:D
  18. greaseguns
    greaseguns
    semi diesel!!!! its only diesel half the time ?? lol
  19. Deuces
    Deuces
    from Michigan
    Scary when you think about it, huh?? :eek:
  20. gimpyshotrods
    gimpyshotrods
    Sure, if it is a two-stroke diesel. Otherwise it is a quarterly diesel.
  21. thats a first for me.... however i did see an engine that had a piston upside down in the bore on a blown alky dragster.... imagine how THAT happened.
  22. Trophydash
    Trophydash
    from Tulsa, OK
    My x-uncle had an old Dodge pickup with a flathead that had done that, and have seen it in an old Super H tractor.
  23. jdj9410
    jdj9410
    from Paris TX
    Seen that. Also seen Hypers turn to powder and fill the intake. Had a bag of the debris on the bench for a long time, finally threw out cleaning up one day. Broke cranks in half. Had one fill pan with alky burn hole in piston. Literaly exploded and had to beat around bolts on VC's, time cover and pan to get apart. Made helluva cool fire. Whole sides of block come out and knock starters off. Stuff gets routine in racing after a long time and ya don't even keep stuff after awhile. But that train engine explosion was spectacular.
  24. Iceberg460
    Iceberg460
    Haven't seen that before, but torn down a couple late model ford diesels and have found pistons missing, biggest chunk we found was about 1/2" across...
  25. You guys collecting other folks broken parts so you don't have to make your own?:D
  26. 94hoghead
    94hoghead
    unless its your house! those are big ass pistons!
  27. 94hoghead
    94hoghead
    Another offering to the gods of speed...........?
  28. Atwater Mike
    Atwater Mike
    Big Daddy Don would've...
  29. Heo
    Heo
    Seen a pontiac 400 with a siezed piston pin that was almost there
    And my 351 Cleveland did that and cracked the cylinder
  30. banjorear
    banjorear
    Dang, talk about incoming! Hopefully nobody got hurt over that one.
