Hot Rods Enhanced Inspection
Discussion in 'The Hokey Ass Message Board' started by statesblue, Dec 10, 2017.
  1. statesblue
    statesblue
    from Luzerne Pa
    I think I'm ready to send my roadster thru enhanced inspection. Kinda nervious but I'm pretty sure I have all the bases covered.
    The biggest question I had was the fan shroud. I have enclosed a picture of what I did. Not sure if it's right or wrong but I like it.
    Well wish me luck. IMG_20171209_141308343.jpg IMG_20171209_141308343.jpg IMG_20171209_075945461.jpg
    mad mikey and chryslerfan55 like this.
  2. oldolds
    oldolds
    That meets the technical requirements for PA. Did you show it or talk to the place doing the enhanced inspection? If he ok's it, then you just need to hope the person who looks at the photo's in Harrisburg agrees that it is ok.
    For the people looking at this posting. Enhanced inspection is a thing in Pennsylvania. It is used when you build a street rod out of assembled parts or want to run street rod plates. Street rod plates allow you to legally run no fenders, bumpers, and hoods.
    mad mikey likes this.
  3. 19Fordy
    19Fordy
    Just for the heck of it, make some "no holes" snap on covers for the shroud
    to see if it improves cooling. Try cardboard first.
  4. Kinky6
    Kinky6
    Good looking roadster. Your fan shroud looks more like a safety guard to me; it doesn't look like it'll help pull more air through the radiator. As long as it does what you need, that's the only criteria. Good luck w/ the inspection. K6
    Texas Webb and lurker mick like this.
  5. It should keep your fingers safe but it won't help with the cooling. HRP
    da34guy likes this.
  6. statesblue
    statesblue
    from Luzerne Pa
    I didn't make the grille for cooling. I just wanted something to satisfy the state. If I have a problem I will alter the grille or I have a form made to make a enclosed shroud. Don't know as I would like the look of an enclosed shroud but if it needs it......oh well
  7. 27 Tall T
    27 Tall T
    from Butler Pa.
    They may make you wrap your headers I had to make shields for my side pipes. Good luck,I feel your pain
  8. The Shift Wizard
    The Shift Wizard
    I was going to say something about the kink in your radiator hose... but then I took a second look. :confused:
  9. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Don't know as I would like the look of an enclosed shroud but if it needs it......oh well >>>
    Heavy Duty Saran wrap from Home Depot. Jack E/NJ
  10. That should pass without a problem . Your headers are passing too, you only need heat shields if they are outside of the frame . Good luck, should be just fine.
  11. Kinky6
    Kinky6
    If you need an enclosed shroud, look for a '54 Buick (or thereabouts) shroud. All steel, nearly square base tapering to round opening and its vintage! What's not to like?
  12. RidgeRunner
    RidgeRunner
    from Western MA
    If you wind up needing a solid shroud I think the body color blue with some firewall white subtle pin striping could let it blend right in and look nice. All the best with the inspection and keep us posted on how everything works out.
    Ed
  13. statesblue
    statesblue
    from Luzerne Pa
    Update. Got my title and Vin plate. Pheww!! Pain in the ass, yes, but hey, I got it and it only took 5 weeks.
  14. Bandit Billy
    Bandit Billy
    Congrats! Reading posts like this makes me glad to live in Washington State.
    mad mikey and lothiandon1940 like this.
  15. ...............Big Congrats!...So can we assume you'll be driving it to the Jalopy Showdown in May?
    lothianwilly71 likes this.
  16. Graystoke
    Graystoke
    Congratulations !! Unfortunately, the state found out that this law is good way to collect sales tax on parts ...... hence all the paperwork ! Safety concerns are secondary. More cars are rejected for sales receipts than construction.
  17. Sometimes I think PA should stand for Pain in the Ass. Glad you got your stuff.
  18. Beanscoot
    Beanscoot
    "Enhanced inspection" sounds about as much fun as "Enhanced Interrogation".
