Hot Rods Engine tick removal
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Feb 11, 2020.
  1. guy1unico
    guy1unico
    My 302 motor has a little tick but it has never hurt performance. As the motor warms up the tick or it can only be a bit heard in a narrow alley. Do you know of any additive that might get rid of this nuisance.
    Thank you,
    Guy
    Boneyard51 and chryslerfan55 like this.
  2. lonejacklarry
    lonejacklarry
    Maybe a lit cigarette on it's little butt?
  3. BLAKE
    BLAKE
    Check oil weight... too heavy can cause a lifter tick. I ran into this in my 401 nailhead when I tried running 20w-50. Went back to 10w-30 and it went away immediately. Read the 1962 service manual, and that situation/fix was listed verbatim in the troubleshooting section.
    Worth a shot...
  4. Doublepumper
    Doublepumper
    from WA-OR, USA
    MMO is my go-to when doing a crud flush. I like to run some in the oil a couple hundred miles before an oil change and some in the fuel....whenever.
    Slopok and alanp561 like this.
  5. inthweedz
    inthweedz
    Is the 302 a Ford or Chev??
    How many miles on the engine??
    Has the ''tick'' slowly appeared, or been there since new??
    If Chevy, try adjusting the valve clearances..
    If it's a Ford, run with the rocker cover off, using feeler guages, run thru all the valve to rocker surfaces with a .010 blade, and see if the ''tick'' dissapears on any valve..
    I have cure noisey valveson Fords by taking a few thou off the base of the rocker pedestal before today..
    Over the years, I have used this (Pro-Ma MBL8 250ml) on Mazda 626's and Subarus with real rattly lifters, with great success..
    We changed the oil with the recommended grade, and added this additive, started up the engine, it rattled for approx a minute until the additive mixed in, then almost instantly stopped rattling..
  6. Mr48chev
    Freshly built and documented engine, Old engine in new to you car, Wrecking yard or used donor engine recently installed in your ride and out for the first drives?
    Last time the oil and filter were changed if it is an older engine?
    I've seen the results of fresh high detergent oil being put in old engines that hadn't had the best of care or timely oil changes by the previous owner. Usually a lot of sludge floating around in the oil until you get in several oil changes at short intervels.
    As Blake said in post 4, too heavy of weight of oil? He seldom misses the mark on stuff like this.
    I've known more than one guy who dumped 50 Wt racing oil in an every day street engine because he now had it in a "hot car" even though the engine was a stone stock used engine with a set of shiny valve covers added. The results weren't always what the guy expected.
  7. 302GMC
    302GMC
    from Idaho
    Maybe it's a GMC ...
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    Have had success with getting it to operating temp for an hour or so with couple of quarts of A.T.F. in it to clean out the lifters. Then do the oil change. :rolleyes:
  9. F-ONE
    F-ONE
    from Alabama
    My Ford 302 had a tiny little tick.
    It was the #1 piston skirt bouncing between the bottom of #1 piston and the crank.
  10. My grandma had a nervous tick, they always thought it was from that metal plate in her head. I'm not so sure, but everytime she turned on the microwave she pissed on herself..... she was a sweet woman
    Papas32, Mimilan, loudbang and 2 others like this.
  11. 6sally6
    6sally6
    You SURE it ain't the fuel pump? Mine make just enough noise to worry me sometimes. Has for the last 10 years.
    6sally6
    You COULD just tell everybody it has solid lifters!;)
  12. Happydaze
    Happydaze
    Small exhaust leaks can sound like a tick from the engine. You've established unequivocally it's and internal engine matter?
    Reminds me I have a header gasket leak to fix on my new build motor that's only been run a few times! That ticks!
    Chris
    sidevalve8ba and rc57 like this.
  13. guy1unico
    guy1unico
    Thanks, funny jokes too:)
  14. Your car's not Lyme green is it?
    Could be serious...
    Chappy
  15. Exhaust leak... I can agree with checking that out. Look for grey traces where the exhaust gases are escaping. Get someone to hold a rag over the exhaust (few seconds...) while you listen.
    Bobby38 likes this.
  16. 54vicky
    54vicky
    if all else fails to cure it buy a good quality set of ear plugs:rolleyes:
  17. 54vicky
    54vicky
    to be serious happydaze and bob,s suggestion is a good one had it happen over the years.the fuel pump spring on the arm is another good luck solving
  18. manyolcars
    manyolcars
    THIS^^^^^
    rc57 likes this.
  19. Truck64
    Truck64
    from Ioway
    Yabut exhaust manifold leaks are typically only under load or acceleration no?
  20. Shutter Speed
    Shutter Speed
    Had a tick in my OT daily driver. Turned into a CLACK!
    Hole the size of a quarter in the exhaust manifold. Bingo. Tick gone.
    Seafoam eliminated the occasional missing in the same truck. Good for now.
  21. BLAKE
    BLAKE
    Also, if you need to chase town the location of the 'tick' noise, use 2-ft of fuel line... one end held up to your ear, then the open end gets moved around the running motor... exhaust manifolds, valve covers, etc, to locate the source. Works a treat!
    Truck64, RoddyB34 and kidcampbell71 like this.
  22. Black Panther
    Black Panther
    from SoCal
    Like others have said could be an exhaust leak. Could be a cracked cast iron exhaust manifold that when heated nearly seals itself shut.
  23. birdman1
    birdman1
    Go buy a stethoscope, works great and is way safer than a solid rod that can puncture you feeble brain when the fan blades hit it !!!
    Truck64 likes this.
  24. Crayons
    Crayons
    Just use a couple feet of heater hose, works like a charm and no danger danger of piercing your ear drum.
    The Shift Wizard and bobss396 like this.
  25. jnaki
    jnaki
    Hello,
    We put in a Racer Brown Cam and complete lifter kit in our 348 Impala after our stock car class racing in 1960. I was the person to adjust the lifters and timing for the motor. The motor was quiet with the hydraulic lifters as a stock motor. But, once the Racer Brown Cam and complete lifter kit was installed, we had to adjust it for a perfectly quiet running motor. In our quiet backyard garage area, we could hear the ticking sound of the motor.
    upload_2020-2-14_5-47-20.png upload_2020-2-14_5-47-29.png upload_2020-2-14_5-47-40.png We used these oil additives in the 348 motor after installing the Racer Brown Cam. A family friend, who is an expert mechanic, told us that it helps with the motor running smoothly and can be added when necessary. He gave us cases of each. A lot of the race cars, from circle track to drag racing were using it for good running motors.
    When we heard the ticking sound, we knew it was time to adjust the valves using our trusty thin feeler gauges. But, several times during our dragstrip and street racing episodes, we put in either Wynn's Friction Proofing or STP oil additive. (Most of the top drag racers used that method for added help for their motors.) That stopped the ticking, but the more we raced, it definitely needed adjusting to get rid of the ticking sound. NOTE: The drag race inspectors did a sound test on those "stock" cars to make sure they did not upgrade their cams and lifters that came from the factory. The ticking noises were a sure give away that solid lifters were installed and not stock.
    Jnaki
    In order to keep it at maximum running tune, my brother always gave me the job of adjusting the constant ticking sound coming from the cam/lifter kit. It worked, it ran better and it stayed quiet for quite some time. Then the cycle started over again after many episodes at the drags or long road trips. The thick oil additives did work, but it came down to making the manual adjustments for a quiet motor.
    In the drive-in restaurant parking lots, when the hoods were opened to talk about racing specs, the motor was always quiet. The motor was telling others that it sounded stock. That was an advantage as it was not stock, but sounded quiet with the fine adjustments made. Additives or fine adjustments, they both worked until plenty of road trip miles and power acceleration runs.
  26. Boneyard51
    Boneyard51
    Guy, I sorry, but I had to laugh at some of those answers, almost spit my coffee out....again! These guys on here never fail me! Lol..... But, I had a OT engine similar to your 302 that had a tick in it, it came in at about 100,000 miles. Like yours, I mostly noticed it while another vehicle or wall was close to the car, then I could hear it. Small metallic click or tick, seemed lighter than a lifter. I just ignored it, as I couldn’t hear it most of the time. Finally quit driving that truck, due to fuel problems at 245,000 miles, still ticking!
    Bones
    Truckdoctor Andy likes this.
  27. guy1unico
    guy1unico
    added MMO to existing oil...that seemed to do the trick but in 200 miles will drain and add new 10w - 30.
    The Shift Wizard likes this.
