Technical engine stall when stopping
Discussion in 'The Hokey Ass Message Board' started by MrNick, Dec 18, 2020.
  1. MrNick
    MrNick
    from Hemet, Ca
    I have dual 94s on my flathead. When I hit the brakes and stop the engine wants to stall and then it speeds up. If I set the idle high enough so that it don't stall when stopping then the normal idle is way too high. I tried raising the float level thinking that fuel is sloshing away the jets but that didn't help. Any ideas?
  2. AC Chapman
    AC Chapman
    Sounds like timing or vacuum.
    VANDENPLAS and porknbeaner like this.
  3. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Check the float levels. Running fuel level should be 11/16" below the gasket surface on the top of the bowl. Requires a "standpipe" tool that can't be bought any more. I described how I made mine in another thread. I hope it's not confusing. Oldness does that to a fella.
    ottoman and dana barlow like this.
  4. Duals. What air filters?
    VANDENPLAS likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    What x38 said.
  6. MrNick
    MrNick
    from Hemet, Ca
    6 degrees BTDC at idle. Mechanical advance dist.
  7. MrNick
    MrNick
    from Hemet, Ca
    K&N
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    VANDENPLAS and jockeyshift41 like this.
  9. Idle mixture
    Automotive Stud likes this.
  10. old school rodder
    old school rodder
    If you have power brake booster, disconnect it's vacuum line then test. I had the same problem, searched everything, then tested the booster. Found it had a leak. Might help.
  11. Im with the float level camp.
