Hey guys I'm looking to grab a ball /flex hone to do some honing for fresh rings. What do the engine guys here recommend for a final grit finish for cast rings (non moly) I'm getting conflicting opinions on this one. Any thoughts? Rat
Dunno have'nt looked into that as yet Ben but I guess that they'd be available from suppliers locally as well. Cheap enuff to find on Epay though. My mail is that 180 grit is the way to go for cast rings (no moly). Rat
the stones in my triple hone are 120 grit, seems to be fine, but i would say 180 too. I bet there is is only one dunny-brush hone grit available anyway.
Mate, there are many diff grits available in different bore sizes as well. Dunny brush grits can vary from b/w 120-380 from what Ive seen. Plain cast iron, moly and chrome rings all usuallyuse different bore Ra finishes due to the different material used in the rings and the different environments/applications that the engines are used for. Engine Pro (where are you?) what finish do you use for plain cast rings? (I think they're Hastings from ROSS Pistons) Rat
Have an engine builder at work Frank, does alot of old hotrod engines. Will ask him monday if i remember
I'm aware there are different grits and recommendations for differing ring types, was more a comment on how it's very hard to source good (ie not chinese cheap)engine building equipment here..maybe I don't know the right suppliers.
