Engine block color question
Discussion in 'The Hokey Ass Message Board' started by movingviolation, Aug 30, 2013.
  1. movingviolation
    movingviolation
    Hey folks...
    After a few setbacks including meeting a girl in a head on collision in my raptor (her fault) and battling some pumpkin issues that restrict much activities.. I am going to get my ass back at the rpu project! :eek:
    I have a new roller 302 that i have converted to carb... and i am struggling with what to do for block color..
    The RPU will either be red metal flake with black interior or Black with red metal flake interior...
    Opinions on a red block? Black block? or a GunMetal Block?
    I know, its my ride do as i want... Yea, i get it! But i'm tossing ideas around and just want a opinion or 2....
    Thanks
    Leon
  2. movingviolation
    movingviolation
    As well, what paint are people having the best results with?!!?!?!?!?!?
  3. 59Apachegail
    59Apachegail
    from New York
    Gun Metal is a cool color, you don't see that too often. I might even do hammer finish if rustoleum made a high heat version of it.
  4. I tried something different on the wagon,,metal cast. HRP
    And I went red with the sbc in the Deuce pickup. HRP
  5. 26hotrod
    26hotrod
    from landis n c
    i used black on mine cause it hides greese drippings & it makes the chrome & aluminum pieces stand out better.i did my oil pan black powder coated & it just keeps everything cleaner.
  6. 1971BB427
    1971BB427
    from Oregon
    I usually go black on most of my engines, but I do like the cast gray color I see some guys running lately. It is a neutral color, and goes with everything really.
  7. I have the engine in my 32 sedan painted black,,I don't like it and will eventually pull the engine and paint it red. HRP
  8. 39 Ford
    39 Ford
    Ford red is my color of choice for any engine. On a hoodless car I would probably try to complement the paint color.
  9. F-6Garagerat
    F-6Garagerat
    The 283 in my A Pickup is Flathead Ford dark Green, almost black, got it from Roy Naciwicz. I like it. Orange or Red just didn't so it for me. With this being dark I thought I would have more paint options for the body too. Here's a pic before the heads were painted.
  10. George
    George
    Black is supposed to be best for shedding heat, personaly a fresh coat of Ford Blue looks great! The Gun Metal Grey probably wouldn't be bad.
  11. Dark colors actually absorb heat,,lighter colors reflect.
    But in this circumstance it really doesn't matter. HRP
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    I can't recommend a color but I do recommend using Imron. I paint mine just like you would paint a car, epoxy primer then overcoated with Imron. Holds up great, doesn't fade, and you can wash the engine to keep it looking fresh.
    Not a cheap process but it looks and holds up so much better than any other method I have used.
    Don
    AHotRod likes this.
  13. George
    George
    Supposedly NASCAR reaserch says the opposite about internal heat vs external heat
  14. hemi gasser
    hemi gasser
    X2 this works great and I vote for a metal flake red engine
    Sent from my DROID device using the TJJ mobile app
  15. jazz1
    jazz1
    I would go red block,,or red with black highlights. Not black for sure,,makes it too dark to see under the hood...I painted mine blue 'cause that's the only colour high heat paint I had on hand that day,,,quite hideous IMO
  16. Barn Find
    Barn Find
    from Missouri
    Red motor and red interior would look good in a black car.
  17. movingviolation
    movingviolation
    RED METAL FLAKE!!!
    Now can you get Imron or mix it to flake?
  18. n847
    n847
    Black if your gonna drive it! Black if you want it to look clean! Black...well Black!
  19. n847
    n847
    I like to use the cast coat grey on accessories, to create an extra finish or texture on my stuff, and clear coat parts ther come cast finish. They will hold up forever water pumps, alternator cases, etc.
    and I use any of the hight heat engine paints with success. Its all in the prep. Clean till you think its good enought then clean it 2 more times! Then use wax and grease remover and it will stick and last! I've used it with and with out clear...no noticeable difference in my opinion!
  20. jimstro16
    jimstro16
    I painted mine tonight the old Buick/Chrysler color. I was deciding between this and gold. Just wanted something different than the same old black or screaming orange.
  21. RR496
    RR496
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
    Damn, that really looks good that color. Subtle and classy looking.
    Don
  23. n847
    n847
    I agree thats a nice looking color...that being said if your gonna go custom, Gold is about my favorite!
