Emblem attachment?
Discussion in 'The Hokey Ass Message Board' started by EasyBake, May 22, 2013.
  1. EasyBake
    EasyBake
    from Bedford IN
    So should I drill the newly painted mounting holes out to fit the emblems back in or should I cut the posts of the emblem and use some 3m double sided tape? Decisions decisions!
  2. Drill the holes, mount them right if its something permanent for the car.
  3. Willy301
    Willy301
    The tape will look bad, draw and hold moisture and dirt, and peel off on one of those runs down the road... I agree with prewarcars4me on this one.
  4. Jonnie King
    Jonnie King
    from St. Louis
  5. Should have all holes clean prior to paint. Are they just painted over or are they welded? Now when you drill them out you'll have a perfect spot to start corrosion.
  6. Just remember to put a little touch up paint inside the holes after you drill them out to keep them from rusting...but you already knew that.
  7. DJCruiser
    DJCruiser
    from CT
    drill, baby, drill.
  8. 69f100
    69f100
    from So-Cal
    just had one fall off a car i bought when i went through a pothole, just droll them and put tape on the back and the bolts. double assurance
  9. big M
    big M
    I take a dab of paint on each of the mounting pins, then place it against the fender where you want it to go. Each pin will leave a small dot marking where it needs to be drilled. Just go easy with the drill, don't reef on it and drive the chuck into your paint once the bit cuts through.
    ---John
  10. Mr48chev
    Be careful with the drilling though as any filings that hit on paint will burn into the paint. It's especially a problem when drilling over fenders that stick out. I'd mask the area below the spot where the emblem goes off to keep any drill filings off the paint.
