Quick question from a fng: Can original switches (ignition or headlight) be safely used when converting from 6 to 12 volts? I'm rewiring my '49 Ford completely, but I'd like to use the original switches on the dash. If I can't use them, are their any cool alternatives? Thanks, -49C
Simple answer is yes,12 volts require half the amps of 6 volts to do the the same job.So if the switches are in good shape ,should be no problems.
Switches don't know or care about volts, all that matters with a switch is amps. As long as the switch is in good condition it'll be fine.
I am using all the original switches in my 55 Ford and the original headlight switch in my 37 Chevy p/u and no problems so far
