Technical Electrical help
Discussion in 'The Hokey Ass Message Board' started by firerod, Jun 27, 2017.
  1. firerod
    firerod
    from Colorado
    I am wiring my car and have a question for you electrical guys. In the past I have run two wires from the "BAT" connection on my voltage regulator (just like the drawing in the Bishop/Tardel book), one to the generator and one to feed the fuse panel. Instead of this, can I run two wires off the "+" side of the ammeter, one to the voltage regulator and one to feed the fuse panel?
    derpr likes this.
  2. squirrel
    does the BAT terminal get connected to the generator, or the battery?
  3. firerod
    firerod
    from Colorado
    To the generator.
  4. firerod
    firerod
    from Colorado
    I got my answer on the FordBarn. I am going to connect at the fuse panel. Thanks.
  5. Blues4U
    Blues4U
    from So Cal
    The B or Bat terminal on the regulator should be connected to the positive terminal of the battery (on a negative ground system), maybe thru the ammeter if equipped with one, not to the generator. The A and the F terminals on the regulator go to the generator. But to answer your question, yes you could run a wire from the ammeter to the fuse panel instead of from the B terminal of the regulator. Those 2 points are parallel in the circuit, so it doesn't matter which one you use for a source.
