I ran a search for this and got minimal results. What I'm looking for is, Which donor cars work best to adapt electric wipers to my '62 Falcon? Or who makes a kit that will work as well? Thanx for any input.
Why not just look for a 60-62 Factory Electric Wiper motor? (it was an option) Newport Engineering also has a kit, about $200 http://www.newportwipers.com/products.php?year=1960-62+Falcon&make_id=4
If I don't hear of any other donor car options, I may bite the bullet and cough up the $209. for their kit. It looks like the easiest way to go. Thanx
Several guys in our 52-59 Ford group used the newport motors,high praise from all that used them, well made an not a hard install.
Anyone know of setups that are cable driven that would get rid of the mechanical arms underneath the dash?
I'm really liking the Newport wiper unit. Is it possible to use their switch in the same location as my OEM switch? or does it have to be mounted seperately under the dash?
I got one for my old Falcon on Ebay for $100 I think, and it came with the switch. If you keep an eye out they are out there.
If you're referring to shaft driven (speedometer cables) there are many available in British cars. Was quite the thing to do in the 70s and 80s. pretty much every car magazine wrote articles on them. Someone must have an article hidden away covering this. Surely you are not considering the cable systems with the countless pulleys. had an electric unit in a 60 Ranchero many years ago, so there must still be a few out there.
Check MG & Jags...a Lucas system used for years on almost all British cars. Unusual for Lucas, this system works well. Seems to keep all the smoke in.
It didn't happen very often, but electric wipers were an option on these cars from new. Just keep looking, they are out there.
MG setup adapted to '36 Ford (useful and pertinent because it will show you the mechanisms and how adaptable they are): http://www.jalopyjournal.com/forum/showthread.php?t=325421
I am pretty familiar with the British cable system. It is adaptable and a good solution for some situations. However, if Ford offered electric wipers for your car that hardware is going to be much better in every way.
You can use their switch in the same location but you have to buy switch shaft extension also. Then you can install it back where it used to be. I got Newport wiper unit in my Comet and I'm really happy how great it is and how easy it was to install. Maybe not cheapest but absolutely easiest way to go.
63. contact temporaryrod here on the board. he had a NOS 63 one in his swap meet stuff for ages. i think it's still in the box in the shop.
I have had two wiper motors from Newport and would highly recommend them. I have also installed two others. They go in easy and work great. The first one that I installed was in my 54 Chevy and it has worked for 13 years without a problem.
