I have a 53 GMC 5-Window (2 piece glass) LS Custom with Electric wipers. The wipers do work but they barely cover about 7-10" of the window glass from Left to Right (MAX). Looks like they should be covering about 15"or so... Is there an adjustment that fixes this issue ? Has anyone else experienced this problem ? Thanks in advance, Mike, North Texas
I have a '54 3100 with electric wiper conversion and the blades are only 11" long, so compared to the total glass area, I guess you could say it is small. Especially if you're comparing it to the new factory cars.
I have installed several , Newport Engineering , electric windshield wiper kits, on different model car's. I have almost every time had to adjust the coverage. With this brand , it is a very easy job to do.
Interesting... How do you adjust coverage ? Is there an adjustment on the Cam / Rotating Arm ? Thanks in advance, Mike
Newport wipers use a "Marine wiper" motor. You can pull the cover off and change the "sweep" by moving the crank pin further out [or in] on the gear wheel. You can also reverse the contact plate on the wheel, so it parks either left or right.
