Technical Electric fuel pump - rear breather
Discussion in 'The Hokey Ass Message Board' started by Jonesi, Apr 30, 2020.
  1. Jonesi
    Jonesi
    Hi,
    I'd like to install a electric fuel pump (HARDI German brand) on my Flathead 8BA.
    To get rid of the mechanical pump I have to install a rear breather as I understood.
    Do I keep the fuel pump rod in place or do I have to remove it.
    When I have to remove it. How about oil pressure, as the bushing has a little hole in it to lubricate the fuel pump rod. Can I close the hole? What is the best way. I found no clear instructions on that online or in any book.
    Thanks!
    Cheers
    Jonesi
  2. The 39 guy
    The 39 guy
    I think If you keep the fuel pump rod in place you will keep your oil pressure. Without it you will need to plug the hole.
  3. Jonesi
    Jonesi
    So I can just turn on my turning machine and press a massiv "bushing" inside.
  4. BJR
    BJR
