Electric fan direction on my set-up got condenser front of Aluminum radiator and electric fan behind radiator on engine side --should it bring air in from outside or blow air out from engine area to outside-- Thanks out to grill or
Thanks for all your advise--- So that is the way it is wired to PULL in--- with my fan relay goes on at 200 degrees and off at 185 degrees--Thanks
