Hi- I'm running an old Edmunds intake on my flattie with 2x 97s. I know this intake doesn't feed into a common plenum. Before I installed it I wrote down which carb feeds which cylinders. I have since lost that note. I want to set the idle mixture screws with my Colortune but don't know which cylinder to check for which screw. Any help greatly appreciated! Tom
On mine it's split, the 2 barrels (if that's the correct term for the manifold) on the passenger side feed cylinders 1 through 4 and the 2 on the drivers side feed cylinder 5 through 8.
