Edlebrock question?
Discussion in 'The Hokey Ass Message Board' started by mickeyc, Dec 4, 2011.
  1. mickeyc
    mickeyc
    Hello folks, question? Did Edelbrock ever make intake manifolds from magnesium as well as aluminum? I have an intake that appears darker than normally seen on cast aluminum manifolds. A friend said that it looks like it may be magnesium. I have never encountered reference to such products produced by Edelbrock. The manifold is a 6x2- 392 Hemi unit.
    Thanks for any input on this matter....MickeyC
  2. Blue One
    Blue One
    from Alberta
    I could be wrong but I think the answer is no, only aluminum.
  3. mickeymoto48
    mickeymoto48
    Call Vic and ask him.
  4. Shaggy
    Shaggy
    from Sultan, WA
    try the spark test, or isnt there a deal with battery acid? If it is mag i've never heard of it, it'd have to be special production
  5. Deuces
    Deuces
    from Michigan
    If it feels heavy, then it's probably aluminum...
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Some guys get the bright idea to use EZ OFF oven cleaner to clean a dirty intake,it turns aluminum dark,just a thought.
  7. slickhale
    slickhale
    from Phoenix
    so does the purple degreaser...
  8. 73RR
    73RR
    ...and a few minutes in a caustic hot tank....
  9. 42hotrod
    42hotrod
    from S.E. Idaho
    Or sand blasting with dirty sand will turn them dark also.
    Try spraying a small area with aluminum wheel cleaner designed for non-clear coated wheels. Its basically light grade acid and will etch the aluminum back to a bright color. I always do this after sand blasting one to get the original color back.
    Should brighten it back up.
