I have a 61 econoline with a 144 and three on the tree, im looking for an automatic transmission for it. I found a 66 van with a 240 and an automatic. would this trany bolt right up to me 144. If this doesnt work what would.
I'm pretty sure that's the case, but I would ask Squirrel if I were you. He's helped me out in the past.
240's gonna have the small block bell bolt pattern I believe. You need to look for something with a falcon 6 in it, 170, 200, etc... The 250 is in that series, but it has the bigger small block pattern too. A 6cyl falcon/mustang or a 70's fairmont, zephyr might be a good starting point.
THUNDERBIRDESQ nailed it. This same topic came up about a week ago with a falcon owner with a leaky trans. Quite a number of us chimed in. That earlier post had a lot of good info in it. I would refer you there, but, with the search ability down at the moment, I can't find where it is. I'll get back with you if I can find it again.
FOUND IT! Look on page # 25...Sprout started a thread titled "Falcon Trans???". That should help you out.
Dude, i picked up a 64 Econoline that has a 71-74 Torino 250 swap in it. Mine hauls ass with the C4 behind it. Its a good runner. From what im told, the 240 and 300 are based on the same block. The 250 is actually a smaller motor than the 240 and it has gobbs of torque. Ive heard that the 240/300 is quite a big job for the swap. The 250 drops in with little effort. Id definately go with the 250. Mine fuckin hauls ass!
240/300 and the 250 are not based on the same block. the 250 is also a kick-arse motor. Does the other econoline has all the bits to do the conversion to the 240? If so the swap should be straight forward.
Join up here, read, and ask questions http://fordsix.com/forum/index.php?sid=90e671a4dec073fa47096c8f847f9eaa
