Folks Of Interest Early Stewart Warner gauge thread
Discussion in 'The Hokey Ass Message Board' started by Pat Pryor, May 13, 2016.
  1. KKrod
    KKrod
    These are examples of SW speedometer and tachometer that were used in the 40's with the 2-5/8 smooth bezel gauges. They are smaller requiring a 3-1/4 hole (or 3-1/8 can't remember which) than the standard gauges used today. They are front mounted. Hope these photos help.
  2. KKrod
    KKrod
    When did Stewart Warner begin producing the 2 5/8 smooth bezel front mount gauges? Definitely in the 30's. They were used in the 1935 Miller Ford race cars!! I have seen an original photo of the gauges and dashboard in 1935. These must have been sold as individual gauges for general use. I would like to know when the early style 2-1/16 inch tulip needle front mount gauges were developed. About the same time would seem reasonable to me. de32343c54a7dc3b2ea441df5639f254.jpg 6162313852_86d0a6b91b.jpg 9d3c352d6a447c84b101e72cf6fd2244.jpg
  3. Glen Vassallo
    Glen Vassallo
    Hi all. First post here but long time lurker. Love this site. Just found this lovely gauge. Its stuck on 60 psi, any way of getting it to work properly? Thanks 20190205_100732.jpg
  4. alchemy
    alchemy
    Glen, that is about the cheapest gauge SW ever made, and a nice replacement could probably be found for $20. The bill to have yours professionally repaired would top $100 for sure. Or you could attempt it on your own. Carefully pry the rim crimping from around the bucket a very little at a time, working your way around and around many times. Then see if there is anything inside sticking or obviously broke, and fix it. Then carefully reassemble the bezel by slowly rolling (pushing) the edge back over, round and round. Slow and steady wins the race.
  5. Glen Vassallo
    Glen Vassallo
    Hi alchemy. Thanks for your reply. I guess I'll just leave it as is. I don't need it in working condition. It's just a show piece. If I try to remove the rim I would probably ruin it!! Thanks again
  6. Tim_with_a_T
    Tim_with_a_T
    You can try zapping it with compressed air (set it to maybe 80psi and just shoot the nozzle in the port at the back). Then you can try sticking a vacuum hose (or pump) to get the needle moving. There’s a bourdon tube (kinda like a spring) inside that makes the needle move in response to change in pressure.
  7. Glen Vassallo
    Glen Vassallo
    Thanks Tim. I gave it a few shots of compressed air but it did not help. I will try the vacuum idea. Thanks again
    Tim_with_a_T and loudbang like this.
  8. Speed~On
    Speed~On
    @Django This is an early SW vacuum gauge that is very hard to find with this particular face (Red between 0 - 8) This is a 2-5/8, smooth bezel, curved glass, front mount, crescent needle. How about making one of these?
    kadillackid, enloe and loudbang like this.
  9. Speed~On
    Speed~On
    It only took me 3 years to hunt down the holy grail of 1940's Stewart Warner 2 5/8" front mount gauges....the GAS gauge. This arrived the other day and I'm thrilled. The$e will set you back a little coin, but it's sure nice to finally have one.
  10. Dreddybear
    Dreddybear
    I feel like the blues need some love:
    There’s 14 in my coupe. From left to right:
    Firewall/Engine: amp, vac, fuel press, oil press, oil temp.
    Inside: oil press, water temp, vac, fuel level
    Amp, volt, oil temp
    Trunk: amp, volts
  11. Speed~On
    Speed~On
    Darth Walter rules, Dreddy Bear!! Great Model A and outstanding compliment of vintage S.W. gauges.
  12. Speed~On
    Speed~On
    This should fill my dash.
    kidcampbell71, rod1, enloe and 4 others like this.
  13. Wow....:rolleyes:....impressive !
    loudbang and Speed~On like this.
  14. fleetside66
    fleetside66
    The three types of old style Stewart-Warner "Wings" gauges.
    (1) The Deluxe version, which came with a chrome bezel, curved glass, side light windows.
    (2) The Utility version, which came with a black painted bezel, flat glass & no lighting. Yes, I couldn't help transplanting a chrome bezel on it.
    (3) The Industrial version, which came with a black painted bezel, flat glass & no lighting. Again, I couldn't help myself with the bezel. I like shiny stuff, what can I say?
  15. Speed~On
    Speed~On
    2 more Stewart Warner 2 5/8" Motor Minder gauges added to the collection.
    kadillackid, loudbang and enloe like this.
  16. e1956v
    e1956v
    Alliance Vendor
    Last Sunday I purchased the remaining inventory and equipment from a 90 year old gentleman who owned a speedometer shop in Kansas.
    So now I have two more Stewart Warner test benches to add to the stable at the shop. Plus a ton of NOS Stewart Warner parts to sort through. 20190420_090708.jpeg 20190420_090717.jpeg 20190420_090727.jpeg
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
  17. e1956v
    e1956v
    Alliance Vendor
  18. e1956v
    e1956v
    Alliance Vendor
  19. Brad333
    Brad333
  20. e1956v
    e1956v
    Alliance Vendor
    I think it's all repair parts, there's so much stuff that I just peeked in a few boxes. Parts from all the major speedometer makers Stewart Warner, A.C., Moto-meter/Autolite, King Seeley and Waltham. If there's any gauges or complete units I'll post them on the HAMB.
  21. x77matt
    x77matt
    Love this thread! Here is a set of early gauges I had restored for my roadster project by Chris Schleps (the gauge guy).
    So, a year later I had him restore a matching temp gauge so I could run duals on my flatty, and I have a Scot blower, so I had him build me a custom boost/ vacuum gauge using the guts of a new Stewart Warner. It's 2 5/8 long tail crescent, and matches the rest nicely. Only downside is I only need about 5psi of the boost side with the little blower
  22. x77matt
    x77matt
    I found this curved glass winged manifold pressure recently and it is NOS. I've never seen another- have you guys?
    kadillackid, Speed~On and loudbang like this.
  23. alchemy
    alchemy
    I don't mean to be a Debbie Downer, but your winged manifold pressure gauge seems to have had the bezel removed/replaced. And the color difference on the can verses the fitting port seems too much. I bet that is a rescreened face installed on a later gauge.
    Can you seem any part numbers on the face way on the outside edge?
    Automotive Stud likes this.
    NOS Stewart Warner Greenlines in a So-Cal panel.
  25. x77matt
    x77matt
    I don't think so, it's definitely never been pried off, but maybe someone put a new bezel on it?
  26. rusty valley
    rusty valley
    manifold pressure gauge is very common on the older big rigs, peterbuilt, kenworth, etc
    loudbang and x77matt like this.
  27. alchemy
    alchemy
    Hey Texaco, those look nice! Who did the restoration work for you? I have the complete dash from a '37 Diamond T to use in a hot rod and it needs some restoration of the gauges. And I'm going to have the clock turned into a tachometer.
  28. Fantastic job on the gauges...Wow :rolleyes:
  29. The restoration was done here in New Zealand. We have details somewhere of an instrument repairer in the US, so will find and send them to you.
    kadillackid and loudbang like this.
