Hot Rods early sheetmetal
Discussion in 'The Hokey Ass Message Board' started by easyrider47, Apr 2, 2019.
  1. easyrider47
    easyrider47
    who all makes or sells sheetmetal parts for early Fords?
  2. flatford39
    flatford39
    All the usual vendors sell them. Snyders, Bratton's etc. Most of it is made by howell's in Texas. What ever you do do not buy direct from Howell's. You will pull all your hair out dealing with that Ass#$)%$.
    You can buy direct if you are going to pick up but it takes him months to ship. His stuff is OK but you like all of them you need to massage it some to make it fit correctly.
    You should try Bert's in Denver. I understand he sells original sheet metal and has a pretty good supply of it.
  3. What year early ford's are you referring to ?
    The37Kid, 54vicky and captain scarlet like this.
  4. 54vicky
    54vicky
    that covers a lot of ground from the extremely(1904)to the time you determine as being old as nick said.if as noted if you order from howell's you will be howling in anger(play on words)
